Bolt Kit Advice
Old Oct 31, 2008 | 11:09 PM
reclaimer53's Avatar
reclaimer53
Default Bolt Kit Advice
Hey, I'm looking into replacing all my stock bolts on the primary, timing cover and transmission over the winter. Do I have to remove all the bolts and put on new gaskets or is it possible to replace one bolt at a time and torque it to specs? Just curious if anyone has done this before.
Thanks
2008 Fat Bob Candy Red Sunglo
Old Nov 1, 2008 | 04:43 AM
roadkillvespa's Avatar
roadkillvespa
I have replaced them all one at a time and not had any problem.
Old Nov 1, 2008 | 05:16 AM
jamesrgarner's Avatar
jamesrgarner
What kind of bolts are you going to replace them with? I've been thinking about doing the same to get away from the stock look and eliminate the need for hot toppers.
Old Nov 1, 2008 | 06:19 AM
robzuc97's Avatar
robzuc97
Problem I've run into with the chrome bolts is the coating process changes the thread dimensions and you run the risk of stripping the inserts or rounding out the bolt threads. Run all the bolts through a die to clean them up before installation.
Old Nov 1, 2008 | 09:56 AM
dyna rider's Avatar
dyna rider
Default Bolts
Try the polished stainless steel bolts from Diamond Engineering via Kustom Krome.
CrackHeadBob
May 8, 2016 10:44 PM
hurst01
Mar 9, 2015 08:59 AM
timberwolfz28
Nov 27, 2013 07:48 PM
freshman
Jun 15, 2010 05:12 PM
cpa55
Aug 19, 2007 11:14 AM
