Street Bob Tachometer
Old Apr 5, 2006 | 09:49 PM
Big O Dave's Avatar
Big O Dave
Default RE: Street Bob Tachometer
ORIGINAL: ..but Ill try 2 try
Harley sells a set of chrome earplugs PN-08873HD for $42.40 or they come in wrinkle black for $35.
Holy Cow!!
[sm=icon_cheers.gif]
Old Apr 5, 2006 | 10:57 PM
jaystone's Avatar
jaystone
BVBOB,
I have some tach here for my horse, I will ask her if you can use it to tune you sert. [sm=happybounce.gif]
Old Apr 5, 2006 | 11:11 PM
hoggsbreath's Avatar
hoggsbreath
HD sells a speedo/tack all in one unit for about $410 or so.
If you can't hear your motor, you need louder pipes!!
Old Apr 6, 2006 | 10:28 AM
hd_sob's Avatar
hd_sob
ORIGINAL: Protrucker
You guys realize that the wind noise is going to eventually cause a degree of permanent hearing loss?
HUH???
Old Apr 6, 2006 | 11:02 PM
New Dyna Guy's Avatar
New Dyna Guy
hoggsbreath-
Do u know the HD part #? I dont think it will fit on my handlebar mounted stock speedo. I've seen then in the cataloge, but on tank mounted 4 in speedo's only, thanks.
Old Jan 15, 2007 | 09:36 PM
OLDED's Avatar
OLDED
Anyone install their own tach on a Street Bob? I have mine all installed and can't find the signal source to drive the tach. The HD instructions are not close to complete on where to pick up the signal for a Bob. They are written to support the WG and Softails. Thanks, OLDED
Old Jan 15, 2007 | 09:53 PM
glide05's Avatar
glide05
ORIGINAL: OLDED
Not sure what your tach requires, but on a 2005 you need to connect to pin3 of the ECM connector. This is the source for rpm, you will also need +12 and ground. The ecm connector does not have pin3 loaded, so you will need to get a pin from stealer and crimp the tach wire to it, then insert in the connector.
Sorry - used to know the part # but can't locate it.
Old Jan 15, 2007 | 10:25 PM
OLDED's Avatar
OLDED
Thanks, My instructions said the same thing - there are 2 empty pin locations and either could be the #3. Both are the 3rd. one from the end, one on the top and one on the bottom. I tried a jerry rigged jumper to locate the right one, but neither location gave a signal that would run the HD tach. OLDED
Old Jan 15, 2007 | 10:36 PM
MAchonewon's Avatar
MAchonewon
Good looking windshield. Which one is it?
Old Jan 15, 2007 | 11:01 PM
icecaps's Avatar
icecaps
Reading More Posting Less
Installed a HD 2" Minitach on my 06 FXDI. I used a homemade bracket and a Kuryakyn speaker clamp. It works great and I like to know what RPM I'm at.
[IMG]local://upfiles/23329/8718E4CEAD1F4A2CBA6E3B551FD650DF.jpg[/IMG]
[IMG]local://upfiles/23329/3518362140134DF3990D6596B37F3511.jpg[/IMG]
