WTF ... how do you ...?
Old Nov 11, 2008 | 12:55 PM
SURFOR Chop's Avatar
SURFOR Chop
Default WTF ... how do you ...?
I've lost two nuts that have fallen down on top of the transmission and bounced down under the starter and solenoid ... but they didn't fall through.
How do you retrieve the nuts; and where the f*@# are they????
I tried fishing them out with a hanger but they don't seem to be on top of the transmission itself (nice that they have that 'waffle' top to catch ****); but, unless they're trapped under one of the wires that go to the starter/solenoid, I can't seem to locate them .... Have they fallen back on top of, or are they wedged in between the rear mount and the frame?
Thanks to anyone who's figured this mystery out and shares the answer!
R/
Priest
Old Nov 11, 2008 | 01:02 PM
wescoot2's Avatar
wescoot2
Try a magnet and go fishing for them....
Good Luck,
Ed
Old Nov 11, 2008 | 01:07 PM
dyna rider's Avatar
dyna rider
Default Your Missing Nuts
Magnet and a mechanical fingers will get them out. Have you looked between the primary and the engine ? Yes I know, dumb question, but they can hide in there.
Old Nov 11, 2008 | 01:12 PM
stratosphere's Avatar
stratosphere
i have a little magnet mounted on telescopic car antenna, works good
Old Nov 11, 2008 | 01:59 PM
r00k's Avatar
r00k
Just hold the bike upside down and shake
Old Nov 11, 2008 | 02:04 PM
wkdavistx's Avatar
wkdavistx
Pull the starter and they'll come out really easy. Not that hard of a job (pull outer primary cover, jackshaft bolt, pinion gear/jackshaft, then starter).
Old Nov 11, 2008 | 03:59 PM
bosken's Avatar
bosken
Happened to me couple of times...never found any of them...
Think it´s the bikes revenge to all the parts I cut off....
Old Nov 11, 2008 | 05:45 PM
JRK5892's Avatar
JRK5892
i just start it adn let it shake em loose... nothing falls out... then i chauk it up as the bike was hungry... dont worry about it... for the most part everything is sealed up and it will nto get where it does not belong... just make sure your shift linkage is good and clear of crap
Old Nov 11, 2008 | 08:55 PM
2002fxdp's Avatar
2002fxdp
got all kinds of crap down in there.
figure i get it all back when i pull the engine out in a couple weeks
Old Nov 11, 2008 | 09:25 PM
XKROME's Avatar
XKROME
I started stuffing a rag between engine and primary whenever there is a chance i could drop something down there...cuz if there is a chance, you can bet i'll do it.
