Looking for rear fender strut covers
Old Nov 24, 2008 | 11:24 AM
JRK5892's Avatar
JRK5892
yes they will fit no problem i have powdered them all! you will have no problem... 07Bobber you may finally get the chrome!
Old Nov 24, 2008 | 12:03 PM
07bobber's Avatar
07bobber
I hope so joe
Old Nov 24, 2008 | 12:04 PM
luckyB's Avatar
luckyB
Originally Posted by jeffhatch007
I was reading a post from lorance66 and in his post he attached a web site from germany called u-station.de, they sell a custom fat bob fender. Check it out
I like the looks of that fender... should look bad ***. Any issues purchasing it from Germany? What are you planning for tail light / rear turn signal setup?
Old Nov 24, 2008 | 12:13 PM
jeffhatch007's Avatar
jeffhatch007
sure, I'll let you know when I get them.
Jeff
Old Nov 24, 2008 | 12:23 PM
jeffhatch007
I sent them an email, so I hope they respond. I'll find a way to get it from them.
As far as rear turn/brake, I'm thinking of adding a relay from harley that makes your rear turn also into the brake light, like on the nightsters.
then I'll most likely do a side mount license plate, I'm also add leather bags for traveling.....so I have to make sure it all works together. I will post photos when I start the project.
Jeff
Old Nov 24, 2008 | 12:37 PM
jeffhatch007
07bobber, I just sent jsbridgew a PM about the trade. When I receive them, I'll let you know.
Jeff
Old Nov 24, 2008 | 01:11 PM
Slipstrm's Avatar
Slipstrm
I'm interested in your project as well.
I looked at those fenders, they look sharp.
Old Nov 24, 2008 | 02:13 PM
jeffhatch007
I just hope they will ship from germany. They are nice fenders.
Jeff
Old Nov 25, 2008 | 08:17 AM
Slipstrm's Avatar
Slipstrm
Jeff
If you got the money, I bet they can ship.
I hope the fender cost is not super high.
Good luck!
Old Nov 25, 2008 | 09:17 AM
08fxdf43202's Avatar
08fxdf43202
I'm also looking for a set of Street Bob strut covers for my Fat Bob.
The Fat Bob frame struts are the same length as the Street Bob.
I'm using two Low Rider rear fenders for my project. I've started by cutting one fender in half, down the middle. I stripped my FB rear end down to the frame struts and bolted each half of the cut fender to each frame strut. I then cut a 3" wide strip from the middle of the 2nd Low Rider fender and tack welded in place lapped over the two halfs of the first fender. I test fitted a SB solo seat to align the center strip on the two half sections.
I'll finish it up by filling in the tail light hole for a smooth 'shaved' look, go with a side mount license plate and a 'run-stop-turn' signal module for the stock turn sigs.
I'll probable powder coat the turn sigs black and go with no strut covers (like the 09 SB) unless I can get a set of SB covers.
