Chain Drive conversion?
Old Apr 7, 2006 | 10:11 PM
durf's Avatar
durf
Default Chain Drive conversion?
Before I buy the parts I thought I would run this by the forum to see if anyone has any info on this subject. I'm planning on converting to chain drive to make room on my '98 DWG for my 180mm Avon mounted on a 18X5.5 wheel. My plan is to go with a .90" offset 24 tooth front sprocket then space the rear 48(?) tooth sprocket to line up. I plan to use a 530 o-ring chain. I'm not completely sure of the gear ratio I should use. I want to stay close to stock. I have a 103 stroker kit and put out around 110 hp. Anyone have any thoughts or advice before I start on a trial and error mission?
superprohero
Oct 5, 2018 06:19 PM
8ntsane
EVO
46
Oct 11, 2016 03:09 PM
Daddy454
Nov 11, 2015 03:58 AM
CrazyEarle
Jun 1, 2013 08:22 AM
williegbiker36
May 9, 2012 08:00 AM
