FXD Tyre Choices
Old Nov 27, 2008 | 03:10 PM
Tnbrit's Avatar
Tnbrit
Default FXD Tyre Choices
Hi,are radial Front & Rear tyres available for an 07'FXD.I believe they are a mix of Cross Ply front & Radial rear,is this correct?
Cheers,Brit.
Old Nov 27, 2008 | 03:27 PM
dyna rider's Avatar
dyna rider
Default Tires
Yes they are. Michelin, Metzeler, Pirelli, and Avon, all make radials for bikes.
Old Nov 27, 2008 | 06:17 PM
SuperFastGlide's Avatar
SuperFastGlide
sorry put this on wrong post
Old Nov 27, 2008 | 10:28 PM
CAPDUNN's Avatar
CAPDUNN
Continental Road Attacks. They make a 110/80VR19(slightly wider than the stock 100/90 but only a few millimeters difference in height so ride height will be as close as a stock tire with a 1000 miles on it. You need to use no larger than a 170/60ZR17 on the rear because of the stock wheel rim width of 4.5 inches. The Screaming Eagle 180 rear was specifically designed for a narrow rim. Most other 180 width tires need a 5 or 5.5 inch wide rim. Do not mix and match radials with bias ply tires as this produces weird handling problems. You will get a softer ride and more grip with radial tires.
Old Nov 28, 2008 | 07:24 AM
rounder's Avatar
rounder
so anybodys radial tires will grip more than my metzeler 880's?
Old Nov 29, 2008 | 05:25 AM
Tnbrit's Avatar
Tnbrit
Default Bias v Radial
Thanks,for the replies & info.Cap I have checked out the Conti's,the spec & tests look really good.Have you used them on a Dyna?.Since I started this thread I have checked all the Harley models to see which tyre comes standard on which models,so i'm more informed.My next question is does anyone know the reason/theory for Harley using Bias tyres rather than Radials,on the Dyna's & Tourers.
Thanks,Brit.
aklowrider
Wheels/Tires
Sep 5, 2011 08:27 AM
The Doctor71
Ironhead
Mar 6, 2010 10:11 AM
128auto
Jun 14, 2008 07:22 PM
BillyB
Apr 7, 2008 03:23 PM
gussie78
Apr 26, 2007 01:27 PM
