Battery tender
Old Dec 5, 2008 | 04:27 PM
WS6 Formula's Avatar
WS6 Formula
Run wires directly to the battery (use Loc-Tite). To make a quick connect / disconnect you can solder wires to a banana jack and mount it some where out of sight. Use an additional banana jack on the Battery Tender leads. http://shop3.frys.com/product/237909...H:MAIN_RSLT_PG
Old Feb 27, 2009 | 05:48 PM
MnMitch's Avatar
MnMitch
Stage I
Default BatteryTender
I would remove the seat first to make sure the dealer or previous owner hasn't already intstalled the pig tail for the battery tender. I went through the pain of removing the battery only to discover the pig tail fished through the left side of the bike! Much easier getting seat back on!
Old Feb 27, 2009 | 07:21 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
First thing I would do is take a long hard look around the battery side of the bike for a little two wire plug with a cover plug inserted, it could be on the left side, just look around. Or just take a ride up to the dealer maybe your salesman or service dept can show you where it might be.
Old Feb 28, 2009 | 04:31 AM
04fxdwgi's Avatar
04fxdwgi
Also, please remember safety and to put a fuse ( 3 amp is plenty in the case of JR.) in the positive line as close to the positive connection as possible. This will eliminate possibility of a short burning your bike up.
bill from tn
Jan 22, 2023 04:22 PM
Clash City Rocker
Mar 4, 2014 08:02 PM
deadman77
Aug 11, 2013 07:48 PM
HOG WRANGLER
May 8, 2010 03:17 PM
Handycam
Nov 20, 2008 03:25 PM
