Backwards battery
Old Aug 11, 2013 | 11:34 AM
deadman77's Avatar
deadman77
Default Backwards battery
So yesterday when I got back, I had a brain fade and hooked up the tender backwards. Positive to negative and negative to positive. Left it overnight and saw it this AM. What did I mess up? Looks like it may have drained the battery. Is that possible?
Anything that could have gotten fried? I know its only a small amount of juice going in but what could happen.
Thanks in advance.
Old Aug 11, 2013 | 11:41 AM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
Once my battery tender harness was installed, I would say it is impossible to hook it up with reverse polarity. I am guessing that at worst you could have ruined the battery and battery tender.
Old Aug 11, 2013 | 11:44 AM
K Melancon's Avatar
K Melancon
The battery tender is polarity protected so it should have shut down. Put it back on correctly and see if if begins to charge. When you hook up the wire harness the exposed lead (male) should be the negative and the covered (female) should be positive when comimng from the battery just in case it touches something on the bike
Old Aug 11, 2013 | 11:45 AM
Qdog002's Avatar
Qdog002
My tender has a fuse in it so if I screw up it`s ok.
Old Aug 11, 2013 | 12:47 PM
nevil's Avatar
nevil
Your battery should be OK since most tenders will not charge if the polarity is reversed. Make it easier on yourself and hook up the pigtail to the battery so all you need to do is plug the tender into the pigtail.
Old Aug 11, 2013 | 02:14 PM
bdtaylor1979's Avatar
bdtaylor1979
Old Aug 11, 2013 | 04:24 PM
Robbie13's Avatar
Robbie13
LOSER
You infused 12VDC into your household current. At some point it will discharge into something you plug into your receptacle. Just kidding. I think you will be fine.
Old Aug 11, 2013 | 06:36 PM
K Melancon's Avatar
K Melancon
Read the back of your battery tender. If it is a Deltran Battery Tender product it is reverse polarity protected. I think they also make the Harley charger.
Old Aug 11, 2013 | 06:38 PM
AtkRWC's Avatar
AtkRWC
What type of tender/charger are you using? Most are "Fool Proof"! LOL
Old Aug 11, 2013 | 07:48 PM
FXDXTSport's Avatar
FXDXTSport
My dad always said "you can make things fool proof but you can't make them idiot proof" LOL (no offense to the OP)
bill from tn
Jan 22, 2023 04:22 PM
Clash City Rocker
Mar 4, 2014 08:02 PM
sportyslr
Oct 31, 2009 07:41 PM
jacktana
Jul 7, 2008 10:12 PM
nutmagnet
Jul 7, 2008 07:23 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
