Exhaust Gaskets
Old Dec 8, 2008 | 01:32 AM
rockon's Avatar
rockon
Default Exhaust Gaskets
Weird question...let's say I put some new gaskets in and install the exhaust, but remove the pipes before ever firing up the bike. Do I need to use new gaskets when I remount the pipes or are the ones I just put in ok?
Old Dec 8, 2008 | 01:47 AM
PeeTuneYa's Avatar
PeeTuneYa
The initial 'crush' is there. Say you reinstall with the new/old gaskets? Only concern is they do not leak 2nd time around.
Old Dec 8, 2008 | 07:48 AM
RollaMo's Avatar
RollaMo
You should be fine.
I even managed to re-use my stock gaskets on my 09 Fat Bob when I put the V&H pipes on.
As long as your careful with them and don't tear them up. If you don't hear any exhaust leaks after you fire it back up, your good.
Old Dec 8, 2008 | 07:50 AM
rockon's Avatar
rockon
Originally Posted by RollaMo
You should be fine.
I was wondering about that...so I should definitely know if something's not right when I fire it up?
Old Dec 8, 2008 | 08:06 AM
dyna07custom's Avatar
dyna07custom
I have reused gaskets many times but if one leaks it has to come apart new gaskets are cheap
Old Dec 8, 2008 | 08:27 AM
RollaMo's Avatar
RollaMo
Yes, you'll hear it right away if it's leaking. Exhaust leaks are pretty unmistakable.
And as dyna07 said, if it leaks (even just a little) you need to pull it off and replace the gasket. A leaking gasket will not cure itself and will only get worse.
Old Dec 8, 2008 | 09:00 AM
JRK5892's Avatar
JRK5892
just replace them... they are cheap and exp wiht thunder headers, they are a pain in the @$$ to get on and off... do it right, do it once
sac130e
Dec 18, 2015 02:59 PM
P Diddy
Sep 13, 2012 05:15 PM
ANIMAL03
Apr 23, 2010 08:09 PM
brettnbama
Engine Mechanical Topics
Aug 9, 2009 08:38 AM
niterhyder
Aug 27, 2007 02:45 PM
