Ok got everything installed but having a issue with my tach. It seems to get stuck at 3200 RPM and wont go any higher. Then if you slow the rpms it takes a second for it to drop back down to normal.
It seems to work fine up to 3000 rpm, so Im thinking its a problem with the tach but wanted to see if it could be something on my end before calling them.
I bought the wiring harness from the 07 FXDSE to go along with my other mods. It has the connections for a tach however on my stock plug the signal wire was blank. So I ran the signal wire to hole 3 in the ecm.
It seems to be working now. I took it for a long ride and it would slowly go up a little in RPM. It now seems to of broken free and seems to be working normal.
