FXDF Fat Bob 103ci vs 110ci
Old Dec 19, 2008 | 12:52 AM
C-Cat's Avatar
C-Cat
Originally Posted by Centerline
I just bought a month ago a new Fat Bob. My dealer installed the 103" SHO build using all Screaming Eagle parts, except for the D&D Fat Cats.
It makes 42 RWHP more than a stock 96" and 22 ft lb over stock.
https://www.hdforums.com/forum/dyna-...o-numbers.html
i'd like to see that dyno sheet! you'll need major head work to acheive that kind of gain.
better off to go with a reputable indy or site sponsor and use your stock cylinders bored out and porting your stock heads with bigger intake valves.
for less then $4000 i had this done by fairbanks motors and build included se roller rockers/push rods, se clutch spring, 10:5 to 1 wiseco's, woods 7h cams, ported stock heads with bigger intakes. this included all tear down/ assembly and over 4 hrs. on the dyno
109.9/118 on a 07
fatcat exhaust and aftermarket tuner/airfilter and backing plate i already had on my 74.4/90.1 stage 1 setup.
Old Dec 19, 2008 | 04:11 AM
domenicp7's Avatar
domenicp7
The 103 is efficient and will give you no problems if done correctly. I have over 11000. miles on mine and love it. 89hp and 105ft/lbs of torque. It has low end power which I like and seldom take it over 3200 rpms. It sounds awesome also.
Old Dec 19, 2008 | 06:12 AM
ranman469's Avatar
ranman469
??? With the 10.5 pistons do you run special gas? i want to build mine biger but i still want to get the gas from the pump.
thanks for the tips
Old Dec 19, 2008 | 08:07 AM
C-Cat's Avatar
C-Cat
super unleaded with 10% enthanol or without, but it's getting hard to fine. i'm at 10:4 to 1 and no problem tts master tune runs great 38-42 mpg . actually i'm selling the top end and flywheels, got some bigger ones to go on in the next few weeks.
Old Dec 19, 2008 | 11:48 AM
ElusiveThorn's Avatar
ElusiveThorn
Well I called this afternoon and did find out from the service department at my dealership that is was the big bore SE 103ci. But you all knew that I am sure!
He did confirm his statement from yesterday that the 103 has better performace than the 110ci because of the regulation with emissions.
Old Dec 19, 2008 | 12:49 PM
jaysonL's Avatar
jaysonL
I'd go with the 103. In fact if all is well this spring financially, that's what I'm doing.
Old Dec 19, 2008 | 02:26 PM
rounder's Avatar
rounder
Herr Monk seems to have a great knowledge of performance builds... he might be able to steer you the right direction to get the most out of your money..
Old Dec 21, 2008 | 12:42 AM
Centerline's Avatar
Centerline
for less then $3500 i had this done by fairbanks motors and build included se roller rockers/push rods, se clutch spring, 10:5 to 1 wiseco's, woods 7h cams, ported stock heads with bigger intakes. this included all tear down and assembly.
109.9/118 on a 07
fatcat exhaust and aftermarket tuner/airfilter and backing plate i had on my 74.4/90.1 stage 1 setup.
FYI, CNC ported heads ARE somewhat major over stock, as are the 260 cams and the rest of it. Shoot, I got 98RWHP and 115 ft lbs on a puny Yamaha 102" Warrior with no headwork whatsoever ..... but about $3500 worth of engine work.
The engine runs just fine with super unleaded so far.
The 42 HP gain. Harley claims a max 63 RWHP figure on a stock 96" twin cam. With mine at 105HP, that is a 42 HP difference. Spent a wad to get it there.
View of hidden signage.
Stock head parts on left, SE CNC ported head on right
Old Dec 22, 2008 | 12:53 AM
Centerline's Avatar
Centerline
double post
Old Dec 22, 2008 | 12:55 AM
Centerline's Avatar
Centerline
109.9/118 on a 07
One other thought ...... better off???. I have a 7 year warranty on my worked Harley. The installing dealer informed me they would honor warranty on the bike , but that other HD dealers probably would not. So, better off w/ the fairbanks build?????
