SE Ignition Moduale ??
Old Dec 31, 2008 | 01:23 PM
tkb540's Avatar
tkb540
Default SE Ignition Moduale ??
Does an 05 Carburated dyna need a reprograming from HD? My bike will crank, fire, and stall. Plugs and connections appear to be ok. Any info would be much appreciated!
Old Dec 31, 2008 | 04:10 PM
rounder's Avatar
rounder
should not...I have a DTT ignition module that was set up at the shop I got it from...I believe the SE module needs to be set up correctly to work. The setup is done manually by adjusting the screws on the module. The instructions should have given you a base to go from with your mods.
mjaw
EVO
Dec 30, 2009 04:07 PM
tkb540
Dec 30, 2008 11:27 AM
tkb540
Dec 29, 2008 08:01 PM
jfort
Aug 19, 2007 02:13 PM
rhinoevans
Aug 24, 2005 03:09 PM
