You got a good deal on the shocks. I would also raise the front an inch or so if I were you. I did basically what you are talking about: aftermarket shocks (Ted Tine), fork springs (Progressive), and brake pads (Lyndal). The fork springs are not great but they are better than stock, especially regarding dive. Still, I would go with another brand if I had it to do over. I am also planning a braided brake line on front, a fork brace, and maybe Sputhe mounts (if business gets better that is).
As for why Harley stopped with the good suspension parts, as others have said, there was not enough demand, and the slammed look is a lot more popular than performance upgrades. A lot of H-D riders say if you want performance, get a sport bike, but many of us want more performance along with the Harley sound and feel. You can get a lot better than stock without spending a fortune.
the works spring kit is $125 for the 41mm wideglide so same price or less for your 39mm... the caps are loaded by the springs so be careful opening them and Keep some pressure on em or they will fly off and can damage what they hit.
FXDX-T rear shocks, got them on Ebay for $160. I've ridden a T-Sport and although I didn't really flog it, I did like the higher seat and ground clearance. For that price, I don't think I'll get more shock for the money anywhere else. Why did HD quit using the good suspension components they used to use anyway?!
Progressive fork springs and 10w fork oil. I've found I can bottom out the stock forks without really trying (I weigh 215). Hopefully this will stop.
Superbrace. Had one on my V-Strom, amazing upgrade for the price.
Two sets of HBC HH Sintered brake pads. Supposed to be a good upgrade, I'll combine those with stainless lines at some point.
I got the Dyna factory service manual for Christmas, and I ordered the fork cap socket from Ebay this morning. I've already got a jack and an assortment of tools. I think I've got everything I need.
Any tips? Thoughts on this upgrade? Comments? I'm looking forward to the UPS guy showing up next week
My next step will probably be to upgrade the brakes and shocks...probably brakes first. A lot of interest is shown around here with going to a dual-rotor setup, but I'm not really interested in that...seems like a lot of effort swapping lowers and such when the singled rotor setup can be sufficiently improved, IMO. I'll most likely just upgrade the rotors and pads first.
Probably go to Progressive 440s in the back, haven't decided on what to slide in the forks.
Originally Posted by last saint
buckeye,
You're headed in the right direction. The only change I would make is to stay away from the progressive kit for the front end. Go with Works or Race tech in the front end. As for needing a longer kickstand and such...not true. Here's a pic of a streetbob a friend did with FXDX shocks in the rear. Ofcourse there's a 21 on the front which levels it a bit, but you should be alright.
Are the Works or RaceTech kits noticeably better than the Progressive kits?
Originally Posted by MZBuckeye
Stock shocks are 12.5 these are 13.5, how will it end up 1.75" taller? I don't think it will be a problem. The FXDCI sits pretty low in the back stock, so I don't see 1 inch being an issue with stability.
Depends on the bike doesn't it? I thought the FXDB/F/L had 12" and the FXD/C had 12.5"
Harley makes a dual caliper kit for my 05. But, I recently read an interesting thread on another owners forum about dual vs single calipers and what exactly is the difference/advantage/marketing, and now I'm not so sure I really want to spend the $$$.
I would also like to know the difference between the Prog's and the Racetech's.
I have a FXDCi, and the stock shock lengths are 12.5. I just can see one inch difference being significant. Hell, if a 100 lb rider rode my bike, I bet it would sag around an inch less than with my *** in the seat!
You got a good deal on the shocks. I would also raise the front an inch or so if I were you. I did basically what you are talking about: aftermarket shocks (Ted Tine), fork springs (Progressive), and brake pads (Lyndal). The fork springs are not great but they are better than stock, especially regarding dive. Still, I would go with another brand if I had it to do over. I am also planning a braided brake line on front, a fork brace, and maybe Sputhe (if business gets better that is).
I will gladly raise the front an inch as well, if it makes any difference. How would one go about doing that?
For me, it has nothing to do with wanting a ton of performance, necessarily. I just want to not bottom out when riding two up, and I don't want to rip my footpegs off when riding the Dragon this spring!
My thinking was that raising the front will help the ground clearance even more and keep your trail around the same as stock. I also think the suspension parts will help with the scraping even if you weren't gaining the ground clearance, so I bet you'll be a lot happier with it.
I'm in the same boat as you and rockon re: the dual front discs. I feel like I can improve them enough without going to that trouble (and without adding the unsprung weight).
Yeah, that makes sense. I'm just not exactly sure how to go about doing it. I'll call Race Tech on Monday and discuss it with them. After doing some more reading, I think I'll cancel the order for the Progressive springs, and at least just do the RaceTech springs for now... Sounds like they're a bit better, and hopefully I can add the cartridge emulators at a later date.
If Works doesn't offer springs to raise it, you can do it with the size of the spacer. I had mine raised about an inch without changing the springs (just the spacer) after not liking the height after changing the springs.
The emulators are just cartridges to give improved dampening; they drop into the tubes with the springs, from the top. Only trick is they are not "externally" adjustable, so must be set before you button 'er back together...
