Headlight help needed...
Old Jan 11, 2009 | 03:43 PM
Yonaton's Avatar
Yonaton
Not Smart Enough To Be A Member of HDF
Default Headlight help needed...
This is a pic of the stock headlight on my '09 FXD. The bulb itself sorta sits up inside the blackish mushroom-like thing inside the headlight. The mushroom-like thing has a piece of metal that goes back through the inner shiny part of the headlight.
What I want to know:
Can I yank/cut/bend this thing out of the way? Why is it there in the first place? It looks like it's part of the problem of such crappy lighting at night.
Thanks for any assistance with this. I can't really afford a new aftermarket light at this time, nor even a take off from another bike model that doesn't have that thing. I'd really like to fix the one I have so that I can get better lighting out of it.
http://i34.photobucket.com/albums/d1...d_p1010033.jpg
Old Jan 11, 2009 | 03:45 PM
Lorance66's Avatar
Lorance66
link to pic takes me to a generic photobucket page. No pic.
Old Jan 11, 2009 | 04:24 PM
mud's Avatar
mud
I think you need to leave the blackish mushroom-like thing where it is.
mud
Old Jan 11, 2009 | 04:27 PM
Lorance66's Avatar
Lorance66
yeah you wouldn't want to take that off. The beams focus comes from what light reflects from the inside of the bucket. If that piece were removed you would have a lot less focused light. The bulb might just be weak. I have read good things about the Silverstars.
Old Jan 11, 2009 | 04:51 PM
Gary7's Avatar
Gary7
That is called a "bulb shield." Its function is to prevent stray light from the low-beam filament from exiting the lamp and reflecting back off of rain, snow, or fog and causing glare to the rider (or driver for cars.)
I removed the bulb shield in my Sportster headlight because I wanted to use a selective yellow envelope on my bulb and it would not fit with the shield in place. The shield is held in place by the same screw that holds the spring clip which secures the bulb in the lamp. Just unscrew it, take it out, and then take a hacksaw and cut the shield bracket off right at the point where the hole for the screw is. You'll need to put that part back in there otherwise you can't re-attach the spring clip for the bulb.
Here's a pic of what my light looked like with no bulb shield and the selective yellow envelope on the H4 bulb:
Old Jan 11, 2009 | 05:48 PM
Yonaton's Avatar
Yonaton
Hmmm...I hope someday something better is figured out for stock lighting on bikes.
Anyway, thanks for all the answers. I guess I could try one of the Silverstars (believe it or not, Wallyworld has them) and see if that makes any difference.
Old Jan 11, 2009 | 05:51 PM
wolfman 66's Avatar
wolfman 66
Try aiming your headlight a little higher. It made a lot of difference on mine. I also have the Silverstar bulb.
ReidRik_Von
Nov 29, 2011 12:22 AM
NC SeaDog
Jun 9, 2011 09:30 PM
jcmusic
Jun 17, 2010 04:27 PM
kk6pg
Aug 13, 2009 10:49 PM
Yonaton
Electrical/Lighting/Alarm
Jan 11, 2009 03:39 PM
