heat shield cracking.
Old Jan 12, 2009 | 06:54 PM
imcworth's Avatar
imcworth
Default heat shield cracking.
My Vance & Hines heat sheilds have a crack on them. I called Vance & Hines to see if they will warranty my problem. They said to take a picture of the crack email with the reciept and there should'nt be a problem getting a replacement. However my problem is that when I try to take a picture of the crack the pipes are so shiny that it catches all the reflection of everything around me and you can't see the crack. Any secret of taking a picture off a mirrored object so that I may get the snapshot I need so I can get my Heat shields replaced. thxs
[URL=http://g.imageshack.us/img404/062zn0.jpg/1/][IMG]
[URL=http://g.imageshack.us/img404/061gq5.jpg/1/][IMG]
Old Jan 12, 2009 | 07:03 PM
rambobob's Avatar
rambobob
Try spraying the area with something. Maybe hairspray , it sticks and maybe dull it down.
Just an idea.
Old Jan 12, 2009 | 07:05 PM
rockon's Avatar
rockon
Set it on a tripod or stationary object and turn off the flash. If you can, try setting it to the dim light mode...the slower shutter speed will allow more light in for a good exposure, and if you've got it sitting on a stationary object (no wobbles whatsoever) it'll be clear as well.
Old Jan 12, 2009 | 07:08 PM
bakerm75's Avatar
bakerm75
Put a piece of black cardboard directly behind the camera, and angle it so that you block out the light. (black may not be perfect) green may work also. ( eg... construction paper)
Old Jan 12, 2009 | 07:36 PM
mtnlvr's Avatar
mtnlvr
Lots of pics with varying lighting and settings. Tripod with manual focus. If all else fails, make the crack more visible. Pry it a little to separate thee metal more.
nj_nighttrain
May 13, 2016 10:43 PM
kmnjr
Sep 3, 2011 10:55 PM
FXDF_Lover
Mar 8, 2011 02:11 PM
kahaone
Mar 15, 2010 11:40 PM
jordanball33
Jan 28, 2009 09:34 PM
