mini apes
Old Jan 18, 2009 | 01:34 PM
phog light's Avatar
phog light
Default mini apes
does anyone know if a set of mini apes from a street bob will fit on a superglide without changing any of the cables
cheers
mick
Old Jan 18, 2009 | 01:46 PM
8541hog's Avatar
8541hog
I would think you will need to add wire extensions, these can be bought in kits from J&P, among others.
Old Jan 18, 2009 | 01:50 PM
bberck's Avatar
bberck
I think you can get by with the wiring but will probally have to replace all the cables.
Old Jan 18, 2009 | 01:52 PM
stevengb's Avatar
stevengb
throttle cables are too short and the brake line has a different hard line setup on it. Clutch line could possibly work. I changed my SB's minis to the superglide custom bars and those were the issues I had....I have since changed them back because I had forgotten how much better I like the handling of the bike with the mini apes.
Old Jan 18, 2009 | 02:02 PM
devils haircut's Avatar
devils haircut
cheers
mick
They wont work. My first bar swap was khrome werks sweepers. 9" rise narrow minier than mini apes. They cables BARELY fit and the bars had to be pulled back slightly. HD mini apes would have been to much. Try finding take-off street bob cables that some one swapped out for bigger apes.
Old Jan 18, 2009 | 02:56 PM
archergodwin's Avatar
archergodwin
Exactly what I did. Mini apes and cable set from a street bob. Main control wires were no problem. I relocated my front turn signals down to the forks, but it appears they would be no problem either as there seems to be a fair amount of extra wiring in them as well.
Just finished the clutch cable this morning on my swap, so I'm done with that! Now it's back to finishing the fork bag.
... btw: got the bars and cables used, from a couple guys here on the forum, so the change was easy on the pocket book.
(thks jjwin and jmpancoast!)
Old Jan 18, 2009 | 03:09 PM
DynaDan's Avatar
DynaDan
I just put mini apes on mine a few months ago and I had to get new cables and brake line. I think the wires would have been long enough for the signals, there's some extra tucked up in the frame, but I moved mine to the forks
Old Jan 18, 2009 | 05:07 PM
XKROME's Avatar
XKROME
all I replaced was the clutch cable (Wide Glide take off) moved the throttle cables outside the triple trees, straightened out the brake line with a cheap tubing bender from Harbor Freight and had more than enough wire in the back bone.
Old Jan 18, 2009 | 05:39 PM
archergodwin
Might be a good point to note that stock cables on an '05 are 2" longer than the '07 - '09s FXDC.... and 4" longer than an '06.
Just something to keep in mind...
Old Jan 18, 2009 | 05:42 PM
Wireguided's Avatar
Wireguided
I used stock 07 bob bars ,throttle cables ,clutch cable and brakes lines that i bought from a member here as well..
I bought a longer clutch cable recently just cause i wanted it longer..
