Gauges! Help
Old Jan 21, 2009 | 06:22 PM
MobyMan30's Avatar
MobyMan30
5th Gear
Default Gauges! Help
Im actually buyin an 09 Super Glide this friday...i love the bike except for where the speedo is...i dont know if its cause its mounted on the handlebars or if its the style...i either wanna to change the speedo or buy a new gas tank that will fit that bike with the gauges on the tank...any suggestions?
Old Jan 21, 2009 | 06:27 PM
JayFromPa's Avatar
JayFromPa
Buy a Street Bob...............
Old Jan 21, 2009 | 06:28 PM
PoCoBob's Avatar
PoCoBob
I would seriously think about spending the extra to get a Super Glide Custom. The speedo is already moved to the tank. Probably a lot cheaper then replacing the tank and adding a new speedo. Plus you get tons of chrome.
Old Jan 21, 2009 | 06:31 PM
jmpancoast's Avatar
jmpancoast
You cheapest option would be to do the chrome mounting bracket and backing plate. Makes the speedo look much better sitting on the bars. Changing tanks can tear a wallet up. You can go with a digital speedo, but lose the communication and read out from the ECM.
Old Jan 21, 2009 | 06:34 PM
RAWHIDE07's Avatar
RAWHIDE07
HEY stop now ,if you don't like the looks of the fxd gauges buy a different model,it's way too expensive to change it to tank mount etc. later.I like the big single gauge and the single gas cap so i'm happy.Reminds me of the old vincents and triumph roadburners.Buy the right bike for you the first time and then you won't regret it.
Old Jan 21, 2009 | 06:39 PM
skip3406's Avatar
skip3406
I agree with RAWHIDE07 if you don't the the handlebar mounted speedo buy a different model.
Old Jan 21, 2009 | 06:42 PM
MobyMan30's Avatar
MobyMan30
5th Gear
Yea, I've been lookin into digital gauges to mount on the handlebars.... Is it possible to have a speedo/tach combo mounted on the handlebars?
Old Jan 21, 2009 | 06:58 PM
bberck's Avatar
bberck
I went with the 07 SE Superglides set-up on mine. If you just dont like the mount there are options. If you want it in the tank I agree with others and buy the custom from the start, it will be cheaper.
Pic
Old Jan 21, 2009 | 07:21 PM
jmpancoast's Avatar
jmpancoast
You can go with a separate speedo/tach side-by-side set-up or buy a single speedo/tach unit. Check Harley's website and look in the PDF Accessories Catalog.
chopperone
Sep 25, 2014 12:33 PM
mikelong
Feb 10, 2013 04:16 PM
Heriberto
Jun 16, 2011 12:30 AM
kountry
Mar 20, 2011 02:58 PM
chris Rocklage
Sep 16, 2010 05:27 PM
