Exhaust help...
Old Jan 24, 2009 | 08:05 PM
MobyMan30's Avatar
MobyMan30
5th Gear
Default Exhaust help...
Im bout to buy me some Vance and Hines exhaust. Do I just bolt them up and go? or do I have to re jet the carb or something else???
Old Jan 24, 2009 | 08:19 PM
archergodwin's Avatar
archergodwin
If they are the slip-ons, just bolt up and go.
What bike and year, and what model of V&H?
Old Jan 24, 2009 | 08:31 PM
MobyMan30's Avatar
MobyMan30
5th Gear
09 Dyna Super Glide... and Im getting the Vance and Hines Staggered Shorts or the Big Shots 2 into 2
Old Jan 24, 2009 | 08:36 PM
fixxr's Avatar
fixxr
To get the most out of it you need sert and a open air filter=More power!
Old Jan 24, 2009 | 08:40 PM
archergodwin
Yes, I agree... however if cash comes by in smaller amounts, you can do your pipes first.
Old Jan 24, 2009 | 08:50 PM
rockon's Avatar
rockon
The 09 is EFI and it'll most likely need a remap. I tried just exhaust with XIEDs (they richen the AFR) and had a lot of popping on the decel. You've got a lot of options with remapping...FuelPak, PCIII, SERT, TTS Mastertune......I went with Thunder-Max, which uses the closed loop setup and adjusts your setup the more you ride. The difference after adding the TMax is night and day....the bike runs better, sounds better, and the performance is great.
Old Jan 24, 2009 | 09:28 PM
rjb2's Avatar
rjb2
Installed Rush slip on's stage II air cleaner and had it remapped.
bobscruffy
Sep 8, 2015 06:45 PM
GinsengSullivan
Jun 7, 2015 04:53 PM
OldTyme
Sep 28, 2012 05:33 PM
NWMT
Exhaust System Topics
Mar 12, 2012 02:02 PM
bbqbrisket
May 8, 2009 09:22 PM
