Best method to trim windshields... ?
Old Jan 29, 2009 | 11:14 PM
archergodwin's Avatar
archergodwin
Default Best method to trim windshields... ?
Looking for a good way to trim my quick detach windshield to fit around my new headlight. My first thoughts are using a dremel with a thin cutting wheel and making progressively deeper passes, then cleaning everything up with fine files and fine grit sandpaper.
Anybody else done this?
Old Jan 30, 2009 | 12:03 AM
FatBobRay's Avatar
FatBobRay
I think you have a good plan!
Old Jan 30, 2009 | 12:46 AM
chromedome's Avatar
chromedome
https://www.hdforums.com/forum/chass...ield-pics.html
Old Jan 30, 2009 | 12:47 AM
harleridr's Avatar
harleridr
After I scribed the arc I needed with a grease pencil,I used a diegrinder with a 21/2 inch wheel to cut the radius followed by #60 grit, then #120, then #400 wet. I lowered my Q/D down 1/12 inches over the head light on my W.G.
grump
Old Jan 30, 2009 | 12:50 AM
JayStronghawk's Avatar
JayStronghawk
Thumbs up
Check the link.. I also used a little vegetable oil, does not hurt the shield a bit and cools the blade..
Old Jan 30, 2009 | 02:57 AM
grbrown's Avatar
grbrown
Depends how much material you want to remove. A hand jig saw is one way, which will cut a very narrow slot and can be manoeuvred around complex shapes. Take care and saw slowly, as there is a risk the plastic will stick to the saw blade.
Hand files can be used for removing small amounts of material, or finish off the edge of a sawn section, followed finally by fine abrasive papers. I have a dremel, but don't see it as very useful in this application!
I used all the above (except the dremel) to cut the profile on my windshield:
https://www.hdforums.com/forum/membe...rn-lights.html
Old Jan 30, 2009 | 06:42 AM
dpriest's Avatar
dpriest
I used a jig saw with a fine wood blade. masked the wind shield and the jig saw off first then slowly cut. came out great. use progressive sand paper grits then used a torch on the cut end to give that clear factory finish.
Old Jan 30, 2009 | 06:51 AM
fastfxrs's Avatar
fastfxrs
A dremel works great. That's what I used to take 2" off my standard hieght compact quick release windshield. I taped it off, traced my radius and used a cutting wheel (don't remember what size as I used my nephew's tools). Used a small sanding drum on the dremel after that and finally some hand sanding. No scratches, and its a perfect hieght. Should be easy to cut yours to fit around your head light. Have fun.
tim
Old Jan 30, 2009 | 07:14 AM
grbrown's Avatar
grbrown
Originally Posted by dpriest
...then used a torch on the cut end to give that clear factory finish.
Wow! I'm impressed. Can you explain that a bit more? I have visions of my windshield shrivelling up in front of my eyes, under the heat....
Old Jan 30, 2009 | 08:18 AM
archergodwin
Thank guys! Between your experiences and advice: jig-saw it is!
I do have a nice dremel setup, but frankly I was worried about the cutting wheel speed - even on slow, just melting instead of cutting. I'll use the dremel to help clean things up after.
BTW one article I read, the person used MEK instead of a torch to "re-clear" the edge of the windshield. Pretty ingenious
Well, I've got my weekend project!
