What is the best turn signal relocation kit to use on a narrow glide Dyna? I still want to be able to use my HD quick-detach windshield. I'm not sure how that will work.
I am in the process of putting on a Sportster Custom riser and drag bars and really think the whole setup will be much cleaner with the signals moved to the forks.
check the $50 mod thread... best looking and cleanest on is there... i did a simular set up for my build... used the same brackets they recomend using... here is a pic that shows the bracket (mine is powder coated but you get the idea)
check the $50 mod thread... best looking and cleanest on is there... i did a similar set up for my build... used the same brackets they reccomend using... here is a pic that shows the bracket (mine is powder coated but you get the idea)
+1 I'm in the middle of the same mod, just waiting for the signals. If you mount them on the lower tree, you shouldn't have any clearance issues with the shield. just make sure they're adjusted so they don't hit the tank. my stockers (the big ugly old sigs came too close for my comfort, so i ordered new ones)
And the "free mod" costs even less and looks better too. All you need is a trash can.
I haven't grown a big enough pair to try that one yet. although since I blacked out the lenses and reflectors inside the sigs, you probably can't see them very well anyway
I put the duece style kit on my lowrider. It doesn't move them to the trees but tucks them in closer to the bars and moves them out a little. I don't have pics because my camera is broke.
It was a little nerve racking at first, but now it feels natural.
P.S. I should have re-worded that...sounds like a documentary on prison romance
