16" front wheel mod?
Old Feb 8, 2009 | 01:23 PM
streetfightingman's Avatar
streetfightingman
Default 16" front wheel mod?
anyone done a 16" front wheel mod on a dyna? wondering pros/cons handling wise, and any suspension mods that need to be done to compensate for the smaller diameter tire.
Old Feb 8, 2009 | 01:32 PM
ratt196635's Avatar
ratt196635
well I have a 16 on mine but I have a wide glide front end . I live the way it looks and it handles fine. Only thing that i changed as far as suspension was putting the wide glide front end. I am sure someone has done this with the stock front end so maybe they will post what they did for that.
Old Feb 8, 2009 | 02:41 PM
streetfightingman
thanks for the info, ya i was planning on re-lacing the front rim with a 16" rim and going that rout.
Old Feb 8, 2009 | 03:23 PM
ratt196635's Avatar
ratt196635
the only other problem i can think of is the width of the tire not fitting in between your forks.
Old Feb 8, 2009 | 03:37 PM
ackman1968's Avatar
ackman1968
The actual diameter of the tire is pretty close, it just had more sidewall than the 19. So far I really like the wider tire on the front. I didn't stay with the stock forks so I don't know what you will need to do. A while back I remember deeing a Bob that some one had put the 16 on and I think it was done with the stock mid-glide front. My front tire is a 130/16 and it measures 5" wide, if you have room for it I say do it.
Old Feb 8, 2009 | 04:02 PM
streetfightingman
thanks for the info, i did a quick measurment and looks like there is room for the wider tire. the avon tyre web site claims the 90/130-16" is almost 1" smaller diameter than the stock 100/90-19" the bike comes stock with. wondering if front suspension travel and the smaller tire is an issue i.e. front end bottoming out?
Old Feb 8, 2009 | 04:25 PM
ratt196635's Avatar
ratt196635
dont have that problem on mine but you are going to be useing a stock set up. I dont think it will cause any problems.
99dyna
Nov 2, 2020 08:38 PM
customglide57
May 4, 2014 11:51 AM
js1268
Sep 29, 2007 09:58 AM
brazos95
Feb 20, 2007 07:05 PM
SteelCity
Jul 21, 2006 07:19 PM
