Fork Nut Size
Old Feb 9, 2009 | 04:41 PM
bosken's Avatar
bosken
Originally Posted by thedonthere
If you guys are going 2" down you'll really need to think about your jiffy stand. To be on the safe side it will need to be modified. If you don't you may have problems. I did. I took mine off, heated it and bent it to where I felt more comfortable.
yes! i have that on my list...it´s already to long. Going for the grinding off 5mm mod in under 50$ mods section..
i f that doesn´t work I just need a wall everytime I park..
Old Feb 9, 2009 | 05:05 PM
thedonthere's Avatar
thedonthere
Paul do you think 5mm is going to make much difference? I'm not so sure.................
Old Feb 9, 2009 | 05:29 PM
bosken's Avatar
bosken
yes,,.,according to the mod inventor
If you look under the bike you´ll see a small vertical plate velded on the sidestand, the whole bike rest on this small plate. Grind off 5mm here and you gain approx 1" at the end!
See if I can find the pics in the under 50$ thread..
here is a pic of the plate.. arrow shows the plate.. grind it down and the bike will lean more, easy but true!
Old Feb 9, 2009 | 05:34 PM
FUQUA's Avatar
FUQUA
Originally Posted by bosken
79$ grrr.... my set costed 113$ plus shipping to sweden... well, never mind
what length are those rigid bars? 10" ? wherefrom..
11 1/2 " Struts http://southeastcustomcycles.com/
Old Feb 9, 2009 | 05:46 PM
bosken's Avatar
bosken
thanx fuqua!
bosken's Avatar
bosken
here is the free shorter kickstand mod
https://www.hdforums.com/forum/dyna-...ml#post3258533
Livet
Apr 6, 2014 05:03 PM
Roadking04
Mar 22, 2010 06:30 PM
kylant
Jul 29, 2008 12:36 PM
harleykris
Feb 6, 2008 02:58 PM
harleykris
Feb 6, 2008 02:50 PM
