My Low Rider Mods (Pics)
Old Feb 27, 2009 | 01:57 PM
Streets of Fire's Avatar
Streets of Fire
Originally Posted by creekhed1
Thanks for the Kudos!
AND...STREETS OF FIRE...are you using the stock STEM for your headlight? Can you raise it enough?
Mine is stock and the light BARELY fits against the Frame and seems to be pointed down ever so slightly. I did a light alignment and it seemed like it pointed high enough but I wanna be sure.
Mine's an 04 so I had the top mounted headlight that attached to the ugly eyelid. I bought a headlight stem for a duece on ebay to get enough clearance away from the frame. I can raise up and down as much as I want with this one. I have 2 others stems that I picked up and didn't work out. If you want to see them PM me and I'll send you pictures to see if you think it will work. If it does just pay for shipping and it's yours.
Old Feb 27, 2009 | 02:11 PM
creekhed1's Avatar
creekhed1
Thanks... bit I fear I'd have the same results you had.
I'll grab a deuce stem!!! Thanks for the input.
Old Feb 27, 2009 | 06:17 PM
jcmusic's Avatar
jcmusic
I am looking for a similar light for my 04 LR, is it the Cobra II? Also do you know if an HID system will fit inside it?
Jay
Old Feb 27, 2009 | 07:22 PM
creekhed1's Avatar
creekhed1
No Idea about the HID but yes, it's a Cobra II
Here's the link
http://www.easternperformance.com/in...roducts_id=285
Old Feb 27, 2009 | 08:25 PM
Streets of Fire
I bought it off of eBay... It was called a Duece / Springer style mount. $20 range. I then had to tap the hole as it was blank. All in all it was a pain in the *** but it looks so much better than it did with the stock light.
Old Feb 27, 2009 | 09:08 PM
rjmac53's Avatar
rjmac53
nice...
Old Feb 27, 2009 | 11:55 PM
lowrider966's Avatar
lowrider966
Looks great man....nice additions
Old Feb 28, 2009 | 08:03 AM
creekhed1's Avatar
creekhed1
Oh ya.. I put a 3" tank lift on it too (to match the lines of the 8.5" risers and dragbars).
This pic shows the effect of the tank lift pretty well...
low_n_slow
Jul 7, 2016 02:51 PM
Stanger
Feb 8, 2009 03:26 AM
AdrianVall
Nov 11, 2008 09:12 PM
PsTaN
Feb 1, 2008 11:13 PM
slammedsporty04
Jan 16, 2007 10:56 PM
