Official Dyna service part# thread
Old Feb 27, 2009 | 04:09 PM
devils haircut's Avatar
devils haircut
Default Official Dyna service part# thread
Lets build up a part# resource for all the gaskets/o-rings/seals/bolts etc. needed for service. I think if we can build up a good database, Mud can edit out all the "fat" in the thread and maybe even make it a sticky built into catagories.
Rocker cover gaskets-?
Outer primary gasket----------------------------------60547-06
Mid control shaft tower gaskets------------------------63869-06
Wheel bearings-?
Fork OIL SEAL (2)-------------------------------------46514-01
Fork SPACER SEAL (2)---------------------------------46515-01
All parts are for non-Japan 08 Dyna
Belt Rear 131T (except Japan)-------------------------40046-07
Spark Plug--------------------------------------------32362-04
Spark Plug Wire Front---------------------------------31981-99C
Spark Plug Wire Rear----------------------------------31960--99A
Screw for Rear Seat that goes into fender--------------2952A
Front turn signal kit-----------------------------------68972-00
Battery-----------------------------------------------65989-97B
Pri Housing gasket service kit
Clutch cover gasket
O-ring for magnetic drain plug-------------------------17369-06
Exhaust Gasket (2)-------------------------------------65324-83A
You get the idea! Let's make this happen. Maybe it will keep us busy enough to stop arguing about dumb crap over the internet like nerds!
Old Feb 27, 2009 | 04:27 PM
JRK5892's Avatar
JRK5892
great idea!!!
Old Feb 27, 2009 | 04:28 PM
ratt196635's Avatar
ratt196635
Exhaust gaskets-?
Outer primary gasket-?
Derby cover gasket-?
Drain plug o-rings-?
Mid control shaft "donut" gaskets-? (this is what I'm looking for right now)
Wheel bearings-?
Fork seals-?
Pulley bolts-?
Belt-?
I only have a couple of these to post
Exhaust gaskets-?
Outer primary gasket 60547-06
Above is called tower gasket 63869-06
Wheel bearings-?
Fork seals-?
Pulley bolts-?
Belt-?
Old Feb 27, 2009 | 07:08 PM
devils haircut
I guess not too many people think that this was a good idea, lol.
Oh well, I will keep working on it. I just gotta find somebody with a parts manual.
Old Feb 27, 2009 | 07:33 PM
ratt196635's Avatar
ratt196635
I dont have a parts manual but the wheel bearings changed from 1 inch in 06 to 25mm in 07 to now so we would need to list all the numbers I have some more numbers just have to get out to the shop and see what all I have written down.
Old Feb 27, 2009 | 07:43 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Didn't change to 25mm until '08.
Old Feb 27, 2009 | 07:53 PM
ratt196635's Avatar
ratt196635
oops hit wrong number I should proof read my answers
Old Feb 27, 2009 | 08:27 PM
maddoggreene's Avatar
maddoggreene
It ain't much but the drain plug o-rings are:
11105
Don't know why I remember that #, I'm here at work and still know it. Hmmm....
Old Feb 27, 2009 | 08:43 PM
SGMAN's Avatar
SGMAN
You didn't ask for this but I got it one. O2 sensor for 08 FXDC 27683-07. BTW I have a part manual comming in the mail very soon.
08 foward control break pedal 42542-03
Old Feb 27, 2009 | 09:04 PM
mud's Avatar
mud
The devil gives birth to a Part Number List.
it's your baby.
git er done.
my contribution...................
................Owner's Manual......Parts Catalog......Service Manual..
09 Dyna........ 99467-09........99439-09A.........99481-09......09 Dyna
09 FXDFSE.... 99739-09.................................99525-09......09 FXDFSE
08 Dyna........ 99467-08........99439-08A.........99481-08......08 Dyna
08 FXDSE2.... 99739-08........99430-08...........99525-08......08 FXDFSE
07 Dyna........ 99467-07........99439-07A.........99481-07.....07 Dyna
07 FXDSE...... 99739-07........99430-07..........99525-07......07 FXDFSE
06 Dyna........ 99467-06A......99439-06A........99481-06A.....06 Dyna
05 Dyna........ 99467-05........99439-05A........99481-05......05 Dyna
04 Dyna........ 99467-04........99439-04A........99481-04......04 Dyna
add suffix for
..................Brazilian Portuguese......BR
..................European Portuguese....PT
..................Danish.......................DA
..................Dutch........................NL
..................French.......................FR
..................German......................DE
..................Italian........................I T
..................Korean.......................KO
..................Norwegian..................NO
..................Polish........................PL
..................Simplified Chinese........ZH
..................Traditional Chinese......TW
..................Spanish.....................ES
.......DoubleCheck and Verify with your source.......
