Clutch adjustment question
Old Feb 28, 2009 | 08:50 PM
Topspin's Avatar
Topspin
Default Clutch adjustment question
Just curious... (I adjusted my clutch freeplay today) The lever was sloppy loose.
How far from the grip must YOU release YOUR lever before the clutch starts to engage?
Mine was immediately but now it's about an inch. (I left about 1/16 of freeplay).
Trying to figure out if I got it right.
Old Feb 28, 2009 | 09:04 PM
Costnsg's Avatar
Costnsg
I just adjusted clutch and cable freeplay this afternoon (you commented on my post on a similar subject). Anyway, I have about the same situation as you describe and I think you're fine.
Mine worked just fine on the ride I took this afternoon in clear, 69 degree weather.
Old Feb 28, 2009 | 09:29 PM
archergodwin's Avatar
archergodwin
I think the standard rule of thumb, is to adjust about a dime's width of play in the cable at the pull handle. For engagement, the inch measurement sounds about right.
Old Feb 28, 2009 | 09:39 PM
Topspin's Avatar
Topspin
Actually, it was your post that got me thinking! It was MY clutch that needed adjusting!
Old Mar 1, 2009 | 12:12 AM
AAA88's Avatar
AAA88
my clutch releases almost immediately upon let down. i adjusted it that way through the primary. the adjustment on the cable is just that..... an adjustment for the cable. the adjustment on the other side of the primary is how you will make up room or slack it for where you want the clutch to release.
Old Mar 1, 2009 | 08:10 PM
Costnsg's Avatar
Costnsg
That makes a lot of sense now that you mention it. Being a short time owner, I looked at the cable adjustment and the clutch adjustment and thought "it will be what it will be" if you follow the manual instructions. I also looked at the routing of the cable (to the right side) and wondered if there could be another adjustment that would change the point in lever travel that the clutch engages. I'm happy with mine as it is now, mostly knowing I have the clutch adjusted correctly.
fxstc1999
Aug 22, 2012 02:18 PM
Kielbaso
Mar 2, 2012 07:57 AM
mi2az
Aug 1, 2011 06:03 PM
Born2cure
Aug 9, 2010 12:32 AM
goutieboy
Mar 3, 2009 08:27 PM
