PCV Install
Old Mar 12, 2009 | 08:22 PM
Wrongturn's Avatar
Wrongturn
Default PCV Install
I'm installing my PCV and had a question but the Fuel Moto guys are closed so i'm coming to you guys. When i unplugged the stock wiring harness from the ECM...i also moved the data plug. When i connected the grey connector from the PCV to the ECM...should i have repositioned the data plug where it was or ziptied it with the stock wiring harness that was detached?
Old Mar 12, 2009 | 08:28 PM
davidc's Avatar
davidc
I left mine under the fuse cover, it was about 1/2 inch short of reaching the original spot where I took it off, so I zip tied it to the PC-V connector under the cover so it wouldn't flop around.
Old Mar 12, 2009 | 08:33 PM
Wrongturn's Avatar
Wrongturn
Thanks. Just wanted to make sure i wasn't alone not getting the data plug back to where it started.
Old Mar 12, 2009 | 08:51 PM
bberck's Avatar
bberck
I was able to get mine back were it was.
gregski
2014-2024 Touring Models
Jul 4, 2017 12:58 PM
Krazy8s
Apr 3, 2013 02:39 AM
jcanrun
Jan 25, 2010 09:31 PM
Cloud09King
May 12, 2009 09:39 PM
Scubadog
Mar 31, 2009 06:50 PM
