Ridin' Hard
Old Mar 18, 2009 | 02:49 PM
  #61
Leonidas's Avatar
Leonidas
Originally Posted by jake.h
BTW, here is a tid-bit of info I found on the web about rider leaning/ground clearance:
Why do Road Racers Stick Out Their Inside Knee?
It lets the bike lean less for a given speed. By sliding off the inside of the seat, the rider's body weight is moved towards the inside of the corner. This means the bike needs less lean for a given speed and turn radius. As ground clearance is often the limiting factor in cornering (particularly at higher speed) this allows the rider to corner at higher speeds.
Here's some nerd info that describes turning geometry:
T = arctan [V^2/(G*R) ]
V is your velocity, R is the radius of your turn, G is the gravitational constant. T is the "lean angle." It's the angle between (1) the horizontal, and (2) a line from the contact patch of your tires through the center of gravity of the bike-rider system.
Hanging off and sticking out your knee moves the center of gravity of the system to the inside, while leaving the bike more upright, so you don't run out of ground clearance.
+1 I was trying to think of a way to say the same thing, but you've done a much better job of describing it then I could have
hd wheelie king
Feb 24, 2022 10:19 AM
byersmtrco
Mar 3, 2018 02:21 AM
Nemosengineer
Jan 1, 2017 11:36 PM
green-n-mean
Jan 23, 2012 12:37 PM
Shizims
Aug 2, 2009 12:42 PM
