Fork Chatter advice needed
Old Mar 17, 2009 | 08:05 PM
nfccrwr's Avatar
nfccrwr
Default Fork Chatter advice needed
I'm getting a lot of chatter over small bumps in my forks. Do I need to adjust them? This is not bottoming out. This is a used bike so is it possible someone did maintenance and left out a part? Thanks for the advice. The knowledge on this site is a real resource! 2007 Dyna Low Rider
Old Mar 18, 2009 | 06:03 AM
jmpancoast's Avatar
jmpancoast
There have been lots of issues with the front forks on the 06 - 07 bikes. The washer under the steering stem nut has been deemed too soft to retain the torque needed for proper seating of the fork neck bearings. Harley published a service bulletin about a fix for this condition.
Basically, this fix involves replacing this washer with a new hardened washer and new torque specs on the stem nut. Adjustment of the adjustment nut under the upper triple tree and a fall away test are also needed for this fix.
Here is a copy of the bulletin. Be aware, there may be revisions to this bulletin.
Several guys on this forum have taken their bikes to the dealer to have this work performed. Some experienced the same problem, even after the dealer said the work had been completed. If the dealer simply removes the steering stem nut, replaces the washer, then torques the stem nut, the problem will likely NOT be corrected. The adjustment nut must be properly adjusted and a fall way test done. Lots of instances of shortcuts by the service departments have been experienced.
Old Mar 18, 2009 | 07:44 AM
HELDVR's Avatar
HELDVR
Default Heed jmpancoast's warning!
If you tightened the steering head too much, the bike will become very unstable and act as if the trail is too low!
Anyway, this problem is very fixable!
Good Luck!
Old Mar 18, 2009 | 08:21 AM
dyna07custom's Avatar
dyna07custom
is it fom the forks the tree is it a rattle?
Old Mar 18, 2009 | 12:12 PM
db252's Avatar
db252
Have your fork oil changed to heavy duty. I am aware of the washer as well but that is usually a clunk sound. If you get the chatter under light front braking or over small bumps, it is usually the fork oil since stock is like water. Floating rotors are also a source of sound that some here but I'm still waging on the fork oil.
Old Mar 18, 2009 | 01:50 PM
JRK5892's Avatar
JRK5892
what is "chatter" the sound alot of times will tell you what it is... what does it sound like?
Old Mar 18, 2009 | 04:38 PM
palmbeachcpl's Avatar
palmbeachcpl
Arrow Fron end chatter
I got it too on my 2008 Dyna FXDL Loe Rider. Took it to the dealer they test drove it and said it is normal. I have a friend with a 2009 and his does the same thing. I would worry about it.
Old Mar 18, 2009 | 07:29 PM
ackman1968's Avatar
ackman1968
Loose suspension parts that make noise be it bearings, rotors or internal dampening parts aren't normal. Mine was quiet when I bought it and developed the "clunk" and the sound varied depending on road conditions. Any of the items mentioned can effect the handling and saftey of the bike so it is best to address the issue. Mine was the steering head bearings as most probably are. One thing to keep in mind is sound travels. It can start in one part of a vehicle and sound like it is coming from some where else.
Old Mar 18, 2009 | 09:11 PM
reesmicm's Avatar
reesmicm
Default chatter
I have the same chatter on my 09 Fat Bob - trying to figure out source. If it's a clunk, the front stem bearing are loose. If it chatters, it's something different. There seems to be a couple possible chatters, one is the front fork topping out on the small bumps and one comes in with braking. I put brembos (HD touring take-offs) on the front and they work very well, but under strong braking it appears (visually) that the bottom fork legs are flexing back and forth, chatter could be from that (maybe?) or there is a chattering type noise that could be the fender twisting under tension under braking which maybe a fork brace could fix. In short, it's very hard to tell what the chatter is from, but if it's a clunk, its steering head bushing, if it chatters, it not the steering head bushing (from my experience)
Old Mar 18, 2009 | 09:38 PM
BigJfxdwg's Avatar
BigJfxdwg
I'ld check every single bolt on the bike. I was going crazy with what I thought was a noise from my front end and when I couldn't find it I just started hitting every nut and bolt with the wrench, found a bunch of bolts that weren't tight, I locktited them and cranked em all down, clatter was gone.
