Fork Chatter advice needed
ADJUSTMENT
Bearing Adjustment (Fall-Away)
1. Support motorcycle in an upright position so the front
end is completely suspended and the vehicle is level.
2. Remove all accessory weight, such as a windshield, that
may influence the way the front end swings. If clutch
cable is routed so it pulls the front end one way or the
other, disconnect it.
3. Place a suitable marking material, such as masking tape,
over the fender tip.
4. Install a pointer so the base is stationary on the floor and
the pointer indicates the center of the fender. The front
end should be straight ahead, however the balance point
may be slightly off center.
5. Check steering head bearing tension.
a. Tap the fender on one side until the front end begins
to fall-away by itself. Label this point on the marking
material.
b. Repeat the previous step in the other direction.
c. Measure distance between marks.
6. The distance between the fall-away marks must be 2.0-
4.0 in. (50.8-101.6 mm).
NOTE
If distance measured is 2.0-4.0 in. (50.8-101.6 mm) no bearing
adjustment is needed.
NOTE
If distance measured is outside the range given in step 7
bearing adjustment is needed. See Figure 1-37. To access
the adjuster nut (1) the upper triple clamp (2) must be moved
upward.
7. With HUBCAP REMOVER AND INSTALLER (HD-
41494) unscrew and remove stem cap (3).
8. Bend down the fork stem lock washer (4) tab, and loosen
fork stem nut (5).
9. Loosen upper triple clamp pinch bolts and move upper
triple clamp up enough to expose star nut
10. Tighten one pinch bolt enough to hold upper triple clamp
in the raised position.
11. Tighten or loosen the fork adjuster nut until the measurement
is within limits.
a. If the distance is more than 4.0 in. (101.6 mm), turn
the adjuster nut counter clockwise to loosen.
b. If the distance is less than 2.0 in. (50.8 mm), turn the
adjuster nut clockwise to tighten.
12. Lower upper triple clamp and tighten stem nut to 45-55
ft-lbs.
13. Check fall-away. If it is 2.0-4.0 in. (50.8-101.6 mm),
tighten upper triple clamp pinch bolts to 30-35 ft-lbs
(40.7-47.5 Nm).
14. Repeat the fall-away procedure to be sure the adjustment
is correct.
15. Bend lock tab on lock washer against stem nut and
install stem cap.
16. Install and adjust clutch cable.
17. Test ride motorcycle.
