VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
fork knock?
Old Apr 17, 2007 | 12:55 AM
Granty666's Avatar
Granty666
1st Gear
Default fork knock?
I'vea query to ask other VRSCR owners, do their front forks knock, as they load up under sharp braking? On my2006 bike, bought new on 1st april in QATAR (middle east) at a saving of around $8000$ on what I'd pay fora 2007 modelin the UK. I've been into the dealers here in the Middle east with it, fearing the head bearings we're loose, they say not and it a common characteristic to the Street Rod - I'm not convinced -Has anyone else had thisnoise / suggestions how to cure/minimise it.
Old Apr 17, 2007 | 01:21 PM
CANTDR55's Avatar
CANTDR55
Default RE: fork knock?
Do a search on that problem on this site. It's been talked about before in the Dynas and Softtails section. Sounds like same as them. The nut on the stem may not be tight enough. There was a change in torqe specs for that nut. I think the orig specs said it should be 35/40lbs and really it should be more like 85/90 lbs
Old Apr 17, 2007 | 01:23 PM
kfmorris's Avatar
kfmorris
I agree with the comment below...I also have heard of this issue.
From what I read it was a torque issue also...
Old Apr 20, 2007 | 08:42 PM
kritzell's Avatar
kritzell
My 06 just started clunking in the front end. Good thread here, seems as if everyone has it.
http://www.1130cc.com/forums/showthread.php?t=42929
vessel
Dec 7, 2018 11:25 AM
0maha
EVO
18
Mar 5, 2017 04:47 PM
harleyglen
Apr 28, 2016 10:19 AM
jake.h
Jun 16, 2010 05:14 PM
nfccrwr
Jun 26, 2009 05:00 AM
