06 street bob engine miss
Old Mar 20, 2009 | 09:01 PM
jwatkc's Avatar
jwatkc
Default 06 street bob engine miss
I have an issue that I have not been able to cure. Yesterday, I started my bike, left for the car wash and washed it. The car wash is only 1/4 mile away, not like the bike got hot. After, the bike ran like crap. It spit and sputtered like it had a miss. I thought it might be a spark plug, so I changed them and still the same thing. Sometimes it will idle ok and other times it idles high. When you try to take it down the road, it may start out fine, but when you put a little gas to it, like no power and jerks like it has a miss. Any suggestions?
Old Mar 20, 2009 | 09:03 PM
anubisss's Avatar
anubisss
If you ahve a pcIII check the connector between that and the ECM Sounds like there is water in it. If so to the above, use dilectric grease on it.
Old Mar 21, 2009 | 12:51 AM
jbphoto's Avatar
jbphoto
+1. Sounds like you have a problem with water in the ECM connection.
Old Mar 21, 2009 | 03:10 AM
jwatkc's Avatar
jwatkc
I will have to check that out today, thanks fellas and yes I do have a PCIII.
goat-ee
Jun 3, 2018 02:27 PM
Quickie
Apr 4, 2016 02:58 AM
Looch
Exhaust System Topics
Jun 19, 2013 09:40 AM
pearlandhd
Apr 10, 2010 08:11 PM
eddieape81
Apr 14, 2009 12:41 PM
