Air Cleaner Question
Old Mar 24, 2009 | 06:37 PM
evesweater's Avatar
evesweater
Default fitment
Originally Posted by bluechiphank
i got a used crossbones set up and used an old round chrome cover
Will a Crossbones set-up fit my Dyna? I see an 08 crossbones A/C unit on Ebay. Also, would it require a EFI re-cal?
thanks again
Old Mar 24, 2009 | 07:30 PM
bluechiphank's Avatar
bluechiphank
my set up is from a cross bones backing plate, air tubes, air filter the cover is of a old fxr but any round harley cover will fit best part its stock i run short shots and didnot do a thing to the computer hope i helped you out i just did not want to spend alot of money at this time henry
Old Mar 24, 2009 | 08:22 PM
evesweater's Avatar
evesweater
Thanks. It's so confusing. Half the people say you have to re-do the computer when you switch A/C; the other half doesn't. I'm leaning your way. My Rush slip ons come Fri., and I'm itchin to change the A/C too.
thanks.
nice axle-bolt covers by the way!
Old Mar 24, 2009 | 08:45 PM
Goddahavit's Avatar
Goddahavit
Everyone has different thoughts, when I was shopping I was told change either ac or pipes and you can get by, although probably a bit lean, change both and need some fuel management, whether by a tuner, or stage 1 download.
Also dont be surprised if they charge you labor for the download as well, so 150 plus labor... its a rip, but its a harly as well.
I did the download, and it was probably a waste of money, as I now want a tuner so i'd be 1/2 way there if id have just saved the ac until i had the money for the tuner.
firehawk6
Sep 4, 2017 10:33 PM
parrettdl
Oct 10, 2013 09:48 PM
P51Driver
Jun 6, 2013 09:52 PM
GeorgeH
Aug 26, 2008 02:53 PM
oscarg
Mar 29, 2008 11:04 AM
