Rear fender
Old Mar 30, 2009 | 01:28 PM
packmn's Avatar
packmn
Default Rear fender
Is it possible to remove the rear fender on a 2000 FXDL without removing the rear tire? If so how?
Old Mar 30, 2009 | 06:49 PM
HDDyna2006's Avatar
HDDyna2006
In 06 Super Glide, bolts that hold rear signals also hold fender(bolt head is inside fender), bolt between rear shocks and rear sigs hold fender, wire harness to rear lights runs thru inside of fender thru rubber tubing. check and see if 00 an 06 are the same.
Old Mar 31, 2009 | 01:47 AM
Doughboy's Avatar
Doughboy
if you have a bike lift.drop the shocks.that will give you plenty of clerance
jim70
Aug 16, 2013 10:36 PM
missionwop
Aug 9, 2010 10:40 PM
51hogtied
Flathead
Mar 23, 2010 02:04 AM
jarhead45
Aug 19, 2008 06:30 PM
LabCat
Mar 2, 2008 07:36 PM
