Overheting Mode?
Old Apr 8, 2009 | 01:16 PM
kk6pg's Avatar
kk6pg
Originally Posted by lowridermike
Head bearings? Is that next to the flux capacitor?
Yeah, about 2 inches to the left of it.
Steering head. Neck bearings. Those little round thingys beneath the chrome cap under the risers
Old Apr 8, 2009 | 01:22 PM
lowridermike's Avatar
lowridermike
Originally Posted by RollaMo
Well, your Harley does not have power brakes like your car does. There is no connection whatsoever from the front brake to the engine.
I can't think of any reason that would have any effect on engine idle quality. Unless there is some kind of short in the brake light wiring, and that effects the ECM module in some way. But I am just throwing that out there for one of the experts to think about.
That's something to check. Never thought of that.
Old Apr 8, 2009 | 01:26 PM
lowridermike
Now I know what those are.
Old Apr 8, 2009 | 01:32 PM
R Racing's Avatar
R Racing
Is it in gear with the clutch pulled in??
Old Apr 8, 2009 | 01:38 PM
rounder's Avatar
rounder
It is injected. It runs well and idles smooth without grabbing the front brake. While sitting still, idleing I can feel and see a distinct difference in vibration and tone when the front brake is pulled. When released it runs smooth. Almost like when you push the brakes on your car. It runs fine otherwise. There's always the chance i'm crazy too.
you are clamping the pads down, and the vibration you are getting is transferring from the front end. tightening the stem(fallaway) properly may indeed help with this. Then again if your fall away is in check, different bars react differently to the vibrations our bikes have.
On my bike, mini apes were smooth. I then had a lower bar(3.5" rise, 28" wide) on there and the vibrations were much buzzier(brake handle transfer like what you get was there as well). I have 6" risers on night train drags now and the vibrations are virtually non-existent again.
Old Apr 8, 2009 | 02:53 PM
lowridermike
What's fallaway and how do I check it and adjust?
Old Apr 8, 2009 | 03:27 PM
Morloka's Avatar
Morloka
is it possible that by grabbing a handful of brake you are changing your hand position on the throttle?
Old Apr 8, 2009 | 03:31 PM
maddghost's Avatar
maddghost
they are all different , maybe yours is transmitting the vibration to the front wheel,when you pull the brake you deny that avenue. Maybe I'm just guessing though! The rear cyl. cut off is only if your injected machine has the stage 1 download.
Old Apr 8, 2009 | 07:16 PM
lowridermike
Don't know if it has Stage 1 kit but it does have V&H Short Shots. If you change from stock pipes on Injected bikes do they need the kit? I know the Carb bikes need it.
Old Apr 8, 2009 | 08:11 PM
maddghost's Avatar
maddghost
If you get a stage 1 kit,which I think you mean,the Air Cleaner intake coupled with the V&H exhaust you would then for sure need a stage 1 download which involves having your ecm re-flashed at the dealer. But 1 or the other by themselfs does not necessitate the D/L. The "parade duty" or overheat mode where the rear cyl. shuts down is stock on touring models. mine has the D/L and since then when the engine is warmed up and i stop at several traffic lights , or stuck in traffic it does go into parade mode.
I can only describe this as I hear it.
Regular= bomboom....boomboom....boomboom
Parade mode the bike just goes boom- boom- boom-boom there is no mistaking it for sure!
And No i don't mean KABOOM like some wise @$$ is bound to joke about LOL
rphillips
Dec 17, 2015 05:38 PM
Bagged Sbob
May 4, 2015 07:30 PM
HamToast
Mar 18, 2015 12:23 AM
clarsen2020
Wheels/Tires
Jul 22, 2010 07:32 AM
MAX EVO
Oct 25, 2007 03:29 PM
