99 Road King hard bags on a Dyna?
Old 04-08-2009, 05:24 PM
shawn e.'s Avatar
shawn e.
shawn e. is offline
Default 99 Road King hard bags on a Dyna?
Anyone think it would be possible? I have a line on a set with mounting hardware and rear crash bars. If it would be to much of a PITA I won't call on the guy.
Shawn
Old 04-08-2009, 05:47 PM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
I looked into it, but it would be a lot of trouble to get them to work. Part of the mounting hardware is a bracket that lies flat against the aft down sides of the rear fender that support the back side of the underlying support bracket. Also, the cross brace is tied in to that piece. The FLH fenders are longer and if you tried to just adapt it to where it 'should' go to work it would look kind of out of place. Then, on the forward side of the bags mounting brackets they mount up to the frame around where the passenger foot pegs go on the Dyna. I was thinking there is a 'work around' that would allow them to work with the Dyna, but I ended up abandoning the concept myself and going with the older style FLH bags (pre-'85) ... see my photo below. Only thing to complete my install is the cross brace ... it's on order and I hope to see it this week.
R/
Priest
Old 04-08-2009, 05:51 PM
shawn e.'s Avatar
shawn e.
shawn e. is offline
Right on I kinda had my doubts but wanted to be sure. I like what you have going on! Looks great!
Thanks Shawn
Old 04-08-2009, 05:58 PM
SURFOR Chop
I think they might be a little narrower, but don't have the 'carve out' in the middle where the Road King shocks encroach on the bag ... so, I think the volume is pretty close to the same (they hold a lot) ....
The thing that sold me on this approach is that they have support brackets that can be mounted on the struts (and, of course, the cross brace as mentioned above) ....
I've been using them a little over a week and am really diggin' them ... first time out in the weather, I got a little moisture in the left bag, but I replaced the gasket so hope that solves that issue.
I was able to figure out a pretty simple mounting 'work around' solution that basically extended the stock bag mounting bracket with an 1/8" steel strap. Had to cut the stock and drill a few holes ... that was it ....
I mounted them over my quick detach hardware, so use them with my QD rack and sissy bar ....
See my photo gallery for a couple more photos ....
R/
Priest
Old 04-08-2009, 06:03 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Hard Bags
It looks like you could put your lunch in the R/H bag and the muffler could heat it for you. Does it get warm inside the bag ?
Old 04-09-2009, 12:52 AM
SURFOR Chop
I could put a can of soup in there and open it when I stop for lunch!
I haven't really checked to see if it was hot in there after riding ... my commute has me riding for an hour and a half ... I could bake bread or something!
It isn't quite as close as it looks from that photo ... there's about an inch and a half between the pipe and the bracket, and then there's a stand-off that further isolates the bag from the frame. Also, the bag is fiberglass, so the material should act as an insulator ... huh? Well, I'll check and report back ....
R/
Priest
Old 04-09-2009, 03:34 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Brings back memories! I fitted those bags to my Super Glide back in 1974, but then the frame was the same as the Glides of the day, so no adaptation needed. A Dyna muffler (or FX1200) is much smaller than the dresser muffler that normally lives under those bags. I don't recall heat ever being a problem, in some 40k miles of use.
mfmtc01
06-25-2013 07:01 PM
177hdking
04-01-2012 06:49 PM
06 flstfise
Shovelhead
11-20-2010 07:25 PM
JRK5892
08-25-2009 06:11 AM
Z
10-11-2007 06:37 PM
Quick Reply: 99 Road King hard bags on a Dyna?
