Cheap Attitude Stick
Old Apr 9, 2009 | 10:21 PM
rockon's Avatar
rockon
Thumbs up Cheap Attitude Stick
There must be one out there. $100+ for all these on Cycle Visions, etc is ridiculous. That is all...I have spoken.
Old Apr 9, 2009 | 10:26 PM
archergodwin's Avatar
archergodwin
If you build it..... it will be that much better
If you design it, and have someone fab it - that's okay too
Old Apr 9, 2009 | 10:28 PM
JerryGarcia4295's Avatar
JerryGarcia4295
$5 worth of steel ... gwad I wish I knew as much about fabrication as I do about puters ... anyone wanna make a trade ... come on I know one of you fab guys surfed too much **** and has a sick puter that needs fixed
Old Apr 9, 2009 | 10:35 PM
rockon's Avatar
rockon
I'm with ya Jerry...I would if I could.
Old Apr 10, 2009 | 02:40 PM
Robottom's Avatar
Robottom
Default +1 on build your own
$30 worth of material and 2 six packs of beer. Bought and cut the metal myself and grabbed a welder to bend and stick it together.
Getting the curves in both directions across the fender took a six and half, after that he was on easy street.
https://www.hdforums.com/forum/dyna-...-sissybar.html
Old Apr 10, 2009 | 03:03 PM
shimmon's Avatar
shimmon
You can make a sissy bar pretty easy... Go to tsc(farm supply) and grab a stick or two of 1/2 bar stock... Bend as needed, no need to heat it. Cut as need. Weld as need... If you dont weld, a CERT. welder may charge 10 bucks!
Mikeeeeeeeeee
Jun 3, 2005 09:01 PM
