View Poll Results: Springs vs Ricors
New fork springs
30.30%
Ricor Intiminators
23
69.70%
Voters: 33. You may not vote on this poll
New fork springs vs Intiminators
Old Apr 27, 2009 | 07:03 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Let us know how they work for ya, Vic. And enlist a helper with those tube caps this time!
Old Apr 27, 2009 | 08:04 PM
Low E's Avatar
Low E
Default Ricor
SC,
I faced the same dilemna and opted for the Ricor product. My springs have some milegae on them but I was not sure they needed to be replaced. I went with the intimators and figured if I needed springs I could do later.
The intimators beefed up the suspension enough for me that I am not going to replace the springs. I recommend getting the intimators.
Old Apr 27, 2009 | 08:24 PM
SC-Longhair's Avatar
SC-Longhair
I'll definitely add my $.02 when I can. Sadly, I don't really have a 2nd set of hands available to me. I can handle the job alone. I might have to tweak the squeeze clamp idea a bit. It did make compressing everything back down easier by just squeezing the trigger until the cap was sitting inside the fork but then just twisting the cap to engage the threads was a slight challenge, even with a little fork oil on top of the socket to promote it sliding while in the squeeze clamp fixture. I'll try to photograph that next time.
Old Apr 27, 2009 | 09:34 PM
Richinlc's Avatar
Richinlc
Question School me in on somthing here
I am also looking to upgrade my suspension from stock and have asked about others doing rear shock swap outs but have no information on front suspension. Please give me some info I can use. (I come to you guys first)
Thanks, Rich
P.S. I weight around 260lbs have an 08 Fatbob and ride some on crappy roads. 2up about 30% of the time.
Old Apr 27, 2009 | 10:39 PM
wiegs's Avatar
wiegs
Replacing the front and back shocks is slated for next year. I probably should have done the front sinceI just had it apart. My front end it just too soft in my opinion. I am 200lbs and once I get on the bike the front drops about 2 inches. Is this normal?
Old Apr 27, 2009 | 10:51 PM
doxbike's Avatar
doxbike
Here's the hot set up for single-handed fork cap replacement. XLXR from the Sportster forum fabricated this and I copied it. Yes that is a sprinkler riser used for a spacer on the fork cap socket (from J&P-1 3/8") The clamp/spreader is from Sears. Try to get the in-line trigger vs the pistol grip makes the ergonomics to line it up much easier. The hook goes to the axle.
Attached Thumbnails New fork springs vs Intiminators-fork_spring_clamp_001_medium_.jpg
Old Apr 28, 2009 | 03:54 PM
Ricor Shocks's Avatar
Ricor Shocks
Former Sponsor
Thanks, Rich
I'm 220 and ride a 2005 Dyna. Same forks you have. With the INTIMINATORS installed I find no need to change the springs. At 260 you may want to try it first without cutting the spacer.
Old Apr 28, 2009 | 06:49 PM
Hal64hd's Avatar
Hal64hd
I was considering doing the Springs but after the install of the Intiminators my first impression was WOW!. I see no need for the springs now that I have rode with the intiminators for over a month and 1200 miles. The Intiminators give the best of both worlds
Old Apr 28, 2009 | 06:58 PM
ratt196635's Avatar
ratt196635
I have both springs and the INTIMINATORS just have to take the time to install them. Going to try to do it in the next few days.
Old Apr 28, 2009 | 07:56 PM
SC-Longhair
That looks dangerous. This might be a stretch but do you have some more detailed pics of that? My setup is a bit simpler in design but seems I'd have to modify it a bit to be 100% effective. I borrowed the idea from someone on another sporty forum. Those sporty guys can come up with some stuff, can't they?
