wtf new noise
Old May 1, 2009 | 12:38 AM
lhcstreetbob's Avatar
lhcstreetbob
Default wtf new noise
ok wtf..... new thunderheader, bars ,fairing ,seat power commander.i have a new noise i sounds like a rattle or clicking coming from the motor i took the fairing off it wasnt that i took the heat shields off not that even tightend the brake calipers and headlight. what do you guys think?
Old May 1, 2009 | 12:54 AM
Ratbob's Avatar
Ratbob
My mysterious rattle turned out to be the gas cap. Another possibility mentioned in a different thread is the shifter linkage bolt. Start by checking every fastener you can touch.
Old May 1, 2009 | 01:06 AM
lhcstreetbob
Default noise
great sounds like fun i think im going to change the oil over to synthetic just to cross that off the list too thanks for the tip. ive also heard maybe an exhaust leak i didnt hear it until i put the thunderheader on ?
Old May 1, 2009 | 02:13 AM
benwiggin2's Avatar
benwiggin2
Seems like every time I do something to my bike, my sense of mechanical awareness is heightened to a level of 11 on a scale to 10. You have made changes to your bike that maybe you just aren't used to yet? It's still virtually a brand new bike. I doubt (and hope) that there is anything wrong with it.
Still, you cannot go wrong with Ratbob's advice above,
"Start by checking every fastener you can touch".
Old May 1, 2009 | 03:12 AM
maddghost's Avatar
maddghost
I had the most annoying rattle last summer , drove me near insanity for weeks! Turned out my half helmet visor snaps were loose from running in the wind!
Old May 1, 2009 | 05:22 AM
jmpancoast's Avatar
jmpancoast
Lots have had rattles coming from loose front and/or rear fuel tank mounting points.
Old May 1, 2009 | 06:29 AM
shimmon's Avatar
shimmon
got a sissy bar??? mine rattle two screws completely out on one side and loosened the other two... when you find the loose bolt... put some blue loctite on it... thats the best tool in the box for harleys!
Old May 1, 2009 | 06:36 AM
rockon's Avatar
rockon
Do you have a 2-up fender mount? Mine rattles like crazy when I ride solo...
Old May 1, 2009 | 08:17 AM
AdrianVall's Avatar
AdrianVall
I found the main cause of one of the rattles that I've had with my thunder headers. With my forward controls, the rear brake rod that goes from the controls to the back, was rubbing up against the pipe and rattling EVERYTIME I rode the bike. My front isolator was so bad that it apparently cause the whole motor to move some and begin hitting the pipe. Well, changed out my front isolator mount yesterday and that fixed the problem.
Old May 1, 2009 | 09:26 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Check the rubber piece on your jiffy stand and make sure the jiffy sits against it. Mine got turned around and the jiffy was rattling against the frame.
