Gas Cap
Old May 5, 2009 | 04:26 AM
PoincianaRoadKing's Avatar
PoincianaRoadKing
Default Gas Cap
This sounds crazy but I just bought a 2000 Dyna and found that I cannot turn the gas cap! It doesn't seem to be a locking gas cap. Has anyone else had this problem? Could someone have tightened it too tight?
Old May 5, 2009 | 02:37 PM
benwiggin2's Avatar
benwiggin2
I've heard of that before. Probably going to have to ruin it with channel locks and replace it once you get it off.
Old May 5, 2009 | 02:45 PM
maddghost's Avatar
maddghost
channel locks should do you may not wreck it if you put some rubber leather or cloth between the cap and the grips-be careful not to touch the console too! Good Luck!
Old May 5, 2009 | 10:05 PM
mtnlvr's Avatar
mtnlvr
You're not talking about the left cap are you? Just checking.
Old May 5, 2009 | 10:07 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Uh the left cap is your gas guage... But use a rubber strap wrench on the right one.
Old May 6, 2009 | 06:19 PM
PoincianaRoadKing
On the 2000 there's only one gas cap in the middle of the console with a small guage below it. I've been riding for over 2 years and have never seen anything like it. I'll give the channel locks a shot. thanks.
Old May 6, 2009 | 07:02 PM
dyna rider's Avatar
dyna rider
Default Gas Cap
Strap wrench is the best bet unless you just want to damage it.
Old May 6, 2009 | 07:04 PM
rbabos's Avatar
rbabos
It's the new Harley child proof gas cap.
Ron
Old May 6, 2009 | 07:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Sounds like the ratchet mechanism is acting up. It usually takes about 3/4 of a turn for the cap to start opening. Get a replacement on hand in case you wreck the original then you can cap off the fuel tank with the replacement and no ride time lost, if not needed return it.
Old May 6, 2009 | 08:19 PM
PoincianaRoadKing
I used an oil filter wrench with terry cloth. It didn't even scratch the chrome. Thanks.
CVO SG
2014-2024 Touring Models
72
Dec 16, 2015 11:01 AM
Cobytur
Jul 31, 2013 09:48 AM
WA7MM
Dec 26, 2012 10:36 PM
Corndog
Oct 7, 2011 07:17 AM
