Picking up the HD Black Fin derby cover and wanted to know if I have to remove some of the tranny fluid, or do I just have a helper tilt the bike to the opposite side when I put it on. Is a new gasket a must ?
The HD black finned derby cover does require the pancake style gaskit. I did the same not too far back and the rubber ring gasket for the stock cover fits in a small grove that is not there on the black finned replacemant
The pancake gaskets don't seal worth a crap, i run a thin bead out ultra blue around mine to seal it. Also, your primary fluid should be at the bottom of the oppening. If it spils over when you pull the cover it was over filled.
