Fitting Screamin Eagle Plug Wires
Old May 12, 2009 | 08:31 AM
TWUK's Avatar
TWUK
4th Gear
Default Fitting Screamin Eagle Plug Wires
I'm about to order some red plug wires, purely for looks - part 31937-99B.
I was just wondering how you go about clipping the larger 10mm leads. There's a couple of little clips that hold the standard lead to the top of the horn. I can't see if you can get these off the original lead, or whether there's a replacement clip or clips you need to order along with the leads themselves. Also I guess the small black clip nearer the coils which holds the standard 8mm leads won't clip the 10mm leads.
Anyone know?
Old May 12, 2009 | 08:57 AM
hillbilly deluxe's Avatar
hillbilly deluxe
Cut it off and use a cable tie.
Old May 12, 2009 | 08:59 AM
archergodwin's Avatar
archergodwin
X1...
Old May 12, 2009 | 10:30 AM
JRK5892's Avatar
JRK5892
i did not clip mine at all... no worries they are not going anywhere
Old May 12, 2009 | 10:35 AM
rounder's Avatar
rounder
little zip tie.
Old May 12, 2009 | 10:39 AM
FUQUA's Avatar
FUQUA
Originally Posted by rounder
little zip tie.
+1....I went with the stock location...with some little zip-ties
Old May 12, 2009 | 10:47 AM
TWUK's Avatar
TWUK
4th Gear
OK, thanks all.
Is it that the horn clips are one-use clips, or that they're too small for the larger leads?
And no running problems with the higher resistance cables on the standard coils? I saw a thread somewhere recently where a few people had suspected using SE leads on stock ignition as being behind a few bad-running issues?
Old May 12, 2009 | 11:21 AM
Tony P's Avatar
Tony P
+1
I've had mine installed for months without being secured by a clip.
Old May 12, 2009 | 09:29 PM
Wireguided's Avatar
Wireguided
the HD part number for the ties you will need is # 10177 they come 2 in a package.
I prefer the original style thats all
Old May 12, 2009 | 09:35 PM
rdondes's Avatar
rdondes
This is not a big deal. Use a zip tie.
