Fitting Screamin Eagle Plug Wires
I was just wondering how you go about clipping the larger 10mm leads. There's a couple of little clips that hold the standard lead to the top of the horn. I can't see if you can get these off the original lead, or whether there's a replacement clip or clips you need to order along with the leads themselves. Also I guess the small black clip nearer the coils which holds the standard 8mm leads won't clip the 10mm leads.
Anyone know?
Now insert the tie wrap pig tails through the top holes in your horn bracket, get the other two tie wraps and cut the pig tails off of them (maybe leave a 1/4" on). Now take those two tie wrap heads and slip them up on the two pig tails that are going through the bracket, snug it up.
You can also use the original tie wrap heads, cut the pig tail off then use a regular tie wrap, snug it up around the wire and insert the pigtail through the original head.
To replace the rear clip that goes between the two wires, use a large tie wrap as a spacer, use a solder iron to burn a small hole near the ends, then use two small tie wraps to attach the spacer to the wire.
See below:
Screamin Eagle 10 mm Spark Plug Wires: https://www.hdforums.com/forum/dyna-...lug-wires.html
