pcIII question
Old May 17, 2009 | 04:44 PM
MyBeerBelly's Avatar
MyBeerBelly
Default pcIII question
Hi all
My buddy has an 09 lowrider and a powercommander 3....when we try to load a map it is in the wrong format....It is in pvm format and the software that came with the powercommander is djm format...any thoughts?
J
Old May 17, 2009 | 06:26 PM
SC-Longhair's Avatar
SC-Longhair
Maybe he has a PC V? Or he's downloading PC V maps?
Old May 17, 2009 | 06:33 PM
MyBeerBelly
no its a pcIII for sure....wierd because when i loaded my map last year i had no problem...i emailed powercommander also, but they are slow....thanks...any other ideas?
J
Old May 17, 2009 | 06:47 PM
SuperFastGlide's Avatar
SuperFastGlide
.pvm is a graphics file extension... try renaminng your files to a .djm extension, may work..
Old May 17, 2009 | 06:51 PM
SC-Longhair
but the question is where is he getting the map files that they are renaming them.
Old May 17, 2009 | 06:58 PM
MyBeerBelly
He is getting them right from powercommander.com...we tried to rename them and it will not let you..any other thoughts?
J
Old May 17, 2009 | 07:07 PM
a34655's Avatar
a34655
PVM is a Power Commander 5 map file it will not work in a PCIII. Go back to the site and double check but I believe I read a PCIII will not work on an 09 bike it must be the PC V. I have a 09 Super Glide and a PC V. All the maps come in .pvm format.
Old May 17, 2009 | 07:09 PM
SuperFastGlide
you should be able to change the extension as long as the file isint being used by another program... open any explorer window, like my documents, then go to the top and under tools fo to folder options...then to the view tab... in that options dialog box scroll down and uncheck the box that says " hide extensions for known file types" ... now you should be able to change the extension...
Old May 17, 2009 | 07:15 PM
MyBeerBelly
is it true a pc3 will not work on an 09?
J
Old May 17, 2009 | 07:17 PM
SC-Longhair
They are assuming if you have an 09 dyna that you have the pcV. choose 08 or 07 dyna. that will give you pcIII maps.
