Another 103" Question
Old May 22, 2009 | 06:41 AM
Richinlc's Avatar
Richinlc
Question Another 103" Question
Hey guys, I'm looking to do a 103" stage 2 kit this winter and i was wondering if any of you had before and after dyno numbers for me. I will be having the heads ported not sure where yet. any opinions you guys have about specific components will help greatly
Thanks,Rich
P.S. Still waiting on my oil tep gauge to come in I'll keep you updated on the progress of the mod
Old May 22, 2009 | 08:27 AM
SC-Longhair's Avatar
SC-Longhair
From the research I've done, the after numbers should be hi 90's HP and lo-mid 100's tq. I've read some good things about the SE255 cams.
Doing some headwork to boot should get you a good performing machine. Good luck. You can try google. Also, check out the Latus HD forum. Lots of good info there. The guy who runs it, Mike, is super knowledgable.
Check it here (I found it using "tw6 dyno" as the search criteria):
http://www.harley-davidson-forum.net...play.php?f=118
Old May 25, 2009 | 09:31 AM
07fxdwg's Avatar
07fxdwg
www.larryshotrodsandharleys.com
I have a set of stock heads that Larry did a Stage 1 on them. Have good springs and stainless valves. Made 98hp and 102 tq in a 103 with 9.5:1 flat tops and 251 cams available. $450.00
ninja12
Jan 26, 2016 06:17 AM
cecil1
Jan 27, 2012 01:31 PM
el chivito76
Exhaust System Topics
May 4, 2011 10:23 AM
el chivito76
May 3, 2011 09:05 PM
el chivito76
May 3, 2011 09:02 PM
