Inner primary leak!!!!!!! help
Old May 26, 2009 | 03:11 PM
blackbetty88's Avatar
blackbetty88
6th Gear
Default Inner primary leak!!!!!!! help
I have a 95 wide glide. The inner primary is leaking transmission shaft going into the primary. I have replace those seals twice and the third time i pulled it off those seals looked fine. I am wondering if it is a bearing problem in the primary cover that is letting the trany shaft bounce around. I am lost and if anybody has had this problem or any ideas it would be greatly appreciated. Please Help
Old May 26, 2009 | 03:16 PM
JRK5892's Avatar
JRK5892
sounds like the shifter shaft seal man... pretty common for them to go bad... if you look up the back of your primary you should be able to see it leaking from there if it is
Old May 26, 2009 | 03:58 PM
mark0763's Avatar
mark0763
i had a primary leak as well when i had forward controls on my FXDB. the O-ring seal that mates the inner and outer primary case togehter where the shifter was supose to come through with the mid controls on it sliped down when being re-assembled after installing forward controls caused a pretty nasty leak. seal was like a dollar and a little time to replace it. hope that helps
Old May 26, 2009 | 04:22 PM
HOGRIDA_06's Avatar
HOGRIDA_06
If the main shaft seal keeps going bad maybe your belt tension is too tight.
Old May 26, 2009 | 05:14 PM
blackbetty88
6th Gear
It has a bad vibration when it is warmed up at low rpms. any gear. if that makes a diffrence.
R-Jay
Jun 27, 2012 07:32 AM
drspencer
May 24, 2012 10:59 AM
Robtarra39
May 7, 2011 07:12 PM
Neil
Apr 12, 2011 12:58 PM
splitting_lanes
May 27, 2008 08:52 AM
