Services
Old May 26, 2009 | 06:36 PM
Koonass31's Avatar
Koonass31
Default Services
Hey guys doin a 10,000mi on my 09 street bob and a 1,000 mi on the wifes nightster and i got the oil for the eng and the trans but i have no clue as to what to fill the primary with freind told my 90 weight but that dont sound right also heard ATF was the way to go any thoughts
Old May 26, 2009 | 06:44 PM
rdondes's Avatar
rdondes
Syn3 from Harley-Davidson will be fine in the primary. That's what Harley-Davidson dealers put in the primary when doing 10k service.
Old May 26, 2009 | 06:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Most will agree a good 10w40 oil will work , then some use a synthetic oil, i.e. redline, M1 20w50 or syn3.
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
You're not transferring hydraulic force, so don't use a hydraulic fluid (ATF). Use a fluid that's formulated to be a lubricant first & foremost.
Old May 26, 2009 | 06:51 PM
seniorsuperglideE8
Actually some transfer cases on 4 wheel drive units use an ATF. Most of those are chain driven and automatic trannies have clutch packs and clutch bands that some to work on ATF. Personnally I've used syn 3 in both of my dynas with accumulated miles of 50k and no problems.
Old May 26, 2009 | 07:03 PM
SuperFastGlide's Avatar
SuperFastGlide
90 wt?? NO WAY!! i use 10-40 amsoil in mine
Old May 26, 2009 | 08:27 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Try Redline MTL. It is a 70w80 GL4 gear oil with no moly and just slightly thicker than ATF.
Old May 26, 2009 | 09:15 PM
Koonass31's Avatar
Koonass31
Hey fellas thanks alot for the help appreciate it a hole bunch
Old May 26, 2009 | 11:32 PM
recon_sct's Avatar
recon_sct
10,000 miles on an 09 already, CRAP I need to get out and ride more!
Old May 27, 2009 | 06:17 PM
Koonass31's Avatar
Koonass31
no its 1,000 on the 09 10,000 on the 07 that would be pretty hard core though
