wider tires = handling differences?
Old May 27, 2009 | 12:03 PM
yso191's Avatar
yso191
Default wider tires = handling differences?
It is about time to replace my back tire and may replace both. I'm at 7500 miles on the stock Dunlops and may have 1K left.
Anyway, I am considering putting a 180 on the back and 110 on the front. Will this effect the handling in any way? I'll probably go with Dunlops again just 'cause I'm cheap, and I'm not a knee dragger.
I'm considering this just for looks (poser Fat Bob?)
Steve
Old May 27, 2009 | 12:13 PM
fixxr's Avatar
fixxr
The bigger tires shouldn't be a problem as far as handling,but the front fender isn't made for any thing wider than a 100/90/19.
Old May 27, 2009 | 12:40 PM
yso191's Avatar
yso191
Those figures are the stock front tire. According to this https://www.hdforums.com/forum/dyna-...fxd-wheel.html thread, a 120 is even possible.
Steve
Old May 27, 2009 | 01:16 PM
RonnR's Avatar
RonnR
When I went from stock 160 to the 180, the first thing I noticed is that it doesnt want to lean into the corners near as readily as the stock. You quickly get used to it and just push a little harder.. The look may be worth it to some, but I got terrible milage on my 180, Only got 7,500 miles..
I then tried the Dunlop D407 170. Still looks wide (not as wide) but wider than stock, Handles great, and now have 14k on them with more to go. Think I'll stick with them. However sure want to try Metz & Avon 170's.
Guess I'll look for the best deal..
Old May 27, 2009 | 01:21 PM
2007fxdc's Avatar
2007fxdc
Can't speak to the front tire but I have the 180 on the back and my bike handles better with it.
Old May 27, 2009 | 01:28 PM
Snydcat's Avatar
Snydcat
Same here
Old May 27, 2009 | 01:30 PM
Centerline's Avatar
Centerline
Steve
With a wider rear tire, your biket will be just a tad slower to tip into turns or lean reversals. You will only notice it if you are on a continuously tight and twisty road and are pushing the bike's limits, where the necessary muscling of the beast can tire you out after, say several runs of 300+ turns in 11 miles.......
Old May 27, 2009 | 01:34 PM
sddynagus's Avatar
sddynagus
I've been using the 170 metz on the rear and 100/90 up front since I wore out my stock tires, handle and ware better then the dunlops. Now Ill be going to 110/90 up front, I think it sould fit.
Old May 27, 2009 | 03:43 PM
dyna rider's Avatar
dyna rider
Default Wider Tires
I have a 110 on the front of mine and it fits my Street Bob without any mods to the fender. I also have a 190 on the back and since it's a Michelin it seems to handle better than the stock 160.
Old May 27, 2009 | 04:03 PM
Tat2u's Avatar
Tat2u
thats a great pic of you blastin' thru the twisties centerline
AllenW
Jun 18, 2014 05:54 AM
JRK5892
Nov 29, 2009 09:35 AM
cemax12000
Jun 23, 2009 11:23 PM
jpnelson1978
Jul 2, 2007 10:32 AM
WdGldDave
Jul 20, 2006 12:49 PM
