Finished polishing the rear wheel, along with the brake rotor and drive pulley. I can now safely say this was a lot easier than polishing the front wheel.
Now all I have to do is muster the energy to put it all back together again...
Makes want to buy a mother's power ball , I just can't justify 25$ for that. I use my hands and get nicks and scrapes! I guess one day I will come around.
Madghost, I dont use a powerball. I have 2 soft cloth buffing wheels sistered together and use a drill motor. I dont even use any exotic polishing compounds, even though I have them. I use good old Mothers metal polish, and the $hit works great. Still have a lot of cleanup afterwards, but you got to do that anyway.
Andrew, if you saw how swollen my fingers were after all the grinding and sanding, you'd know why I aint doing your ladys sporty. H&ll, I wont even do my own ol ladys!
I have a new question for the rank and file here.
I know theres been a lot of talk about pulley bolts walking out and snapping off, and I think I night have run across a discrepancy...
The book calls for 60 ft/lbs torque on the bolts, but in the chrome bolt package, it has something else to say. It says first torque to 23 lbs, then torque them to 60° past their 23 lb position.
I'm a little hesitant about crankin them as much as the instructions call for. Best I can figure, that should work out to 100 lbs or more. Even though its a grade 8 bolt, crankin a 3/8ths bolt that far is taking it a little too close to its shear point.
I'm wondering if this isnt the reason theres so many failures with the pulley bolts installed by the dealer.
I dont have the answer, and I'm not sure which way I'm going to go. Just thought I'd throw this out there as food for thought
Yup but with the power ball you don't have to remove the wheel it snakes in where you need it to go.
Thata all fine and dandy if you already have polished wheels on your bike. I had stock FXD wheels, and the spokes and center hub were bare sand cast aluminum. Had to take them apart to grind and flatten the metal so it could be wet sanded and polished. Trust me, its a ton of work.
Now I have something not too many others have.
Wheels the way they should have been from the factory.
Now I have a bit of an update. I suspect my theories were correct.
I torques the bolts to 23, just like the instructions said. Marked the position of the head, and torqued to 60 lbs like the book says. Not even half the 60° the instructions called for. Ran the bolts to 75 and hit the 30° mark. Looks like it'll take 150 lbs of torque (or more) to hit that 60° mark.
I suspect if the bolts were NSF, the 60° might be realistic. SAE aint gonna cut it.
