Help with installation
Old May 29, 2009 | 09:35 PM
Richinlc's Avatar
Richinlc
you had better make sure you don't have to rebalance thoes wheels after such a serious upgrade as that....my god, I needed that laugh like you don't even know thanks man..
Old May 29, 2009 | 10:22 PM
ranger56528's Avatar
ranger56528
Good luck sounds like a serious upgrade....Oh and I have heard that your MPG goes up about 10%...
Foeget the Red Loctite..Go with Industral Green,youll never have to worry again heeheehee...
Old May 29, 2009 | 10:32 PM
travroc's Avatar
travroc
Put the beers down and stop what your doing. Don't you know that this upgrade requires the expertise of a qualified HD Tech. If you do this yourself, you will most definately void your warranty.
Old May 29, 2009 | 10:47 PM
EZ48's Avatar
EZ48
Sweet! You gonna run regular air or synthetic air in the tires?
Old May 30, 2009 | 12:43 AM
loudguyc's Avatar
loudguyc
3rd Gear
a 40 mm valve stem cover seems excessively large. You will need a lot of glue but your definitely going to get noticed at bike night. Just saying..LOL
Old May 30, 2009 | 05:02 AM
Jrsess's Avatar
Jrsess
They screw on using the end with the hole.
Old May 30, 2009 | 08:22 AM
'09fxdb's Avatar
'09fxdb
18"pipe wrench with a 3' cheater should torque them down pretty good...and you should consider an alarm system...they are a hot item..
Old May 30, 2009 | 08:51 AM
thezoeman's Avatar
thezoeman
Don't forget to ad some back pressure on the stems so that you don't twist them out of the rim.
Old May 30, 2009 | 08:05 PM
cujo101's Avatar
cujo101
Forum Safety manager here.
1) Make sure bike is properly placed on the pitbull jack.
2) Secure motorcycle to jack in atleast 4 points.
3) Using caution tape and orange cones make a 10' safety zone around the bike.
4) No one should be in the safety zone without proper safety gear:
a) steel toe harley boots
b) a$$less chaps
c) padded fingerless gloves
d) safety glasses with HD emblem
5) Make sure garage door is completely open for ventilation.
6) Cell phone to be at the ready to call 911.
Old May 30, 2009 | 09:53 PM
Hx3's Avatar
Hx3
Can't believe nobody has stated the most obvious recommendation of all. GET A MANUAL......and use the search function. Sheeesh.
