Knocking in front end
Old Jun 2, 2009 | 10:31 PM
kempilot's Avatar
kempilot
Default Knocking in front end
Hi all, I have a '09 FXD and just started hearing a knocking type sound in the front end when riding over rough road surface or bumps. It sounds almost like struts bottoming out, but I know that is not the case. Any thoughts?
Thank you.
Old Jun 2, 2009 | 10:40 PM
ackman1968's Avatar
ackman1968
Steering head bearings probably need adjusted or the tank bolts may be loose.
Old Jun 2, 2009 | 11:01 PM
kempilot's Avatar
kempilot
Thank you ackman, I will look into both suggestions.
Old Jun 2, 2009 | 11:03 PM
ackman1968's Avatar
ackman1968
Any time, how many miles you have on the bike?
Old Jun 2, 2009 | 11:06 PM
db252's Avatar
db252
Lousy stock fork oil. I had the same problem and changed to the next grade up....I think it was Screaming Eagle Heavy Duty, and that fixed it plus got rid of the front end dipping so much under braking.
Old Jun 2, 2009 | 11:29 PM
kempilot's Avatar
kempilot
2900 fun miles : )
Old Jun 3, 2009 | 08:52 AM
DynaGlyda's Avatar
DynaGlyda
i had the same problem with fork oil, i put new inverted forks on my FXDX, every bump sounded horrible, and the forks were hangin up .... Putting in the correct amount, aswell as the right kind, fixed it no problem... rides like a dream...let me know
Old Jun 3, 2009 | 05:57 PM
RCB's Avatar
RCB
Might even want to check your pinch bolt, axle and caliper bolts torque values.
Old Jun 3, 2009 | 06:44 PM
kempilot's Avatar
kempilot
Thx again guys. With all the advice, I am confident that I will get rid of it.
Old Jun 3, 2009 | 07:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I'd have the tank bolts checked and the steering bearings checked.
